Activity › Forums › Adobe After Effects › AE CS6 11.0.1 CUDA BENCHMARK PROJECT – test your graphics cards!
Ian Mapleson replied 8 years, 9 months ago 94 Members · 336 Replies
Teddy Gage
April 21, 2013 at 7:29 pmThis is very interesting. Been very curious about the Titan’s performance in AE
So basically, the titan seems to brute-force its way through to times that can compete (although not outlass) a speedy 580 setup, despite having less than optimal CUDA performance like the rest of the 6xx kepler series.
However it seems it may be software-limited performance, given that it’s basically just a consumer version of the k20 used in the tesla.
What I’m curious about is viewport performance in maya, and whether it can outperform the radeon 7970…
Teddy Gage
April 21, 2013 at 7:59 pmI find that render time extremely hard to believe from a 6xx series card, unless it is watercooled. Make sure your cache was cleared (if the frame are already on disc it will be 10x faster)
If confirmed, I will add it to the spreadsheet thanks
Teddy Gage
April 21, 2013 at 8:43 pmGuys, I have posted a spreadsheet of these results for everyone in .pdf and .ods format in the benchmark folder.
https://www.teddygage.com/AEBENCHCS6/
Hope these results are informative and thanks to everyone who has posted their info so far. If I didn’t include your results I only used one system per GPU unless the results were radically different (ie amd vs intel).
I would love to get more quadro and tesla results if possible to add to the list. Thanks!
Cesar Siena
May 11, 2013 at 8:14 pmHi, I wonder how did make your Ae CS6 recognize the GTX 675MX card. Could you explain your steps, please? I work on PC’s win8 and latest versions of Ae 11.0.2 and NVIDIA driver, but nothing’s happening. Ae isn’t able to recognize it as a compatible video board. Could you give me some hint? Thank you!
Teddy Gage
May 15, 2013 at 2:00 amI just got a GTX Titan and wanted to post my numbers
intel 3930K @ 4.6 ghz, with Titan @ stock speed = 3:57
intel 3930K @ 4.6 ghz, with Titan OC @ 1110 mhz base clock = 3:40I will be testing this against a 2x GTX 580 in SLI, but still waiting on my second card
right now
GTX 580 3GB I am getting 5 min 5 sec with GPU clock at 925 mhz, or 5:45 at stock speed. testbed is intel 3770k @ 4.7 ghz
Teddy Gage
May 23, 2013 at 5:14 pmJust because I was curious, with double-precision on, the benchmark renders slower. Just tried it. not by much, maybe 5-10%? Honestly I have no idea what double-precision is useful for. Anyone can fill me in?
I was also wondering whether it was possible to edit a preferences file allowing AE to use more available VRAM. I understand limiting cards with less memory, but I’m only getting 4.5 GB of usable VRAM with the titan in AE. Granted, that is a lot but it would be great to get another GB and I doubt the OS needs more than 500 mb of overhead.
Tijmen Kuipers
May 23, 2013 at 6:11 pmProcessor Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
Memory (RAM) 32,0 GB
EVGA Nvidia GeForce GTX680 4GB DDR5 Classified (PCI-e)Render time: 7min 16sec
Alex Barrios
May 24, 2013 at 3:17 am -
Adrian Thompson
May 26, 2013 at 11:11 pmMac 4,1
8-core 2.26Ghz
32GB Ram
7200rpm hard driveLatest version of Mountain Lion and Nvidia Drivers.
Nvidia GTX 570, 2.5GB (flashed by MacVidCards)
6 Min, 51 Sec
