Activity › Forums › Adobe After Effects › AE CS6 11.0.1 CUDA BENCHMARK PROJECT – test your graphics cards!
Ian Mapleson replied 8 years, 9 months ago 94 Members · 336 Replies
James Osbun
January 29, 2013 at 2:18 am -
Peter Vartovnik
February 5, 2013 at 7:15 pmHP EliteBook 8560w
Win7 Pro (64bit)
i7-2670QM CPU @ 2.20GHz
16GB RAM
NVIDIA Quadro 2000M32min, 5sec
Huggo
Thanos Kagkalos
February 6, 2013 at 8:40 pmHow is that possible i do 7:07 on i7 3930k @ 3.5 / 32 gb ram / GTX 680 phantom 4gb / ssd intel 330
Isnt that a bit slow? i also noticed when i was working 3ds max my gpu based rendering was like 1 minute less than what i was reading in forums… What i ve possibly done wrong here? thanx
Eddie Pratt
February 16, 2013 at 11:48 pm5 mins 48 seconds
Mac Pro 4,1 Early 2009 – Dual 2.26GHz
24GB RAM
Lion 10.8.2Single GTX 570 2.5GB VRAM – GPU 895MHz overclocked – Point of View (POV) TNT
In general I’m finding the performance of my machine on After Effects 6 better with just 1 graphics card (GTX 570) rather than adding the GT120 to use as a GUI card. This configuration works fine in Davinci Resolve lite too.
Outside this benchmark I’ve also noticed that the GPU is not used in lots of different situations whilst the CPU is heavily loaded i.e. when not using the Ray-traced 3D renderer. It seems like there must be a more efficient way of offloading CPU onto GPU when it’s sitting there idly with practically no usage while the CPU struggles on!
Cheers,
Eddie
Michael Stephens
March 11, 2013 at 9:22 pmSystem specs:
AMD Phenom X4 9750
8G PC2-6400 (400Mhz) (5-5-5-18)
Windows 7 64-bit Professional SP1GeForce 560 Ti: 11 minutes & 27 seconds
GeForce GTX Titan: 4 minutes & 33 seconds.
MOBO only has a PCI-E 1.1 slot so performance should be even better on a PCI-E 2 and 3 slot.
Matt Deloach
April 3, 2013 at 2:48 pmPC w/ Windows8:
[ 8mins 36secs ]
Core i7 920 CPU (@ 3.9ghz OC)
12GB DDR 1600 Ram
GTX 470 (1GB ram)———————————————————
iMac (late 2012) – OSX 10.8.3 Mountain Lion[ 11min 2Secs ]
Core i5 3.2Ghz
16GB DDR 1600 Ram
GTX 675MX (1GB ram)———————————————————
MacBook Pro Retina (mid 2012) – OSX 10.8.3 Mountain Lion[ 29min 49Secs ] – Ouch. I spent 2Grand on the thing!
Core i7 2.3Ghz
8GB DDR 1600 Ram
GTX 650M (1GB ram)Looks like I will be updating my home PC soon thanks to this thread!
Roberto Tafuro
April 13, 2013 at 10:50 amIntel i7 980x
GTX Asus 680 4GB
12 GB ram
First try 7min
Second try 18 sec…
Just to say that there are a lot of things that makes a render faster.
If you run a ram preview for ex it takes on my machine 4 minutes and the rendering takes 18 seconds after the ram preview.
If you lock the preview with the Caps the rendering is made in 5 minutes the first time. If i disable the Nod32 the rendering is done in 4 minutes too…
Funny esxperiments 🙂 -
Carlos Yus
April 17, 2013 at 9:12 am -
Carlos Yus
April 17, 2013 at 6:54 pm -
Kahuna Kahuna kj
April 21, 2013 at 3:36 pmJust for the record:
Intel 3770K @ 4.7Ghz
GTX Titan @ 1000Mhz (boost to 1167Mhz)
32GB @ 2400MhzTime to render: 3m28s
With Titan at stock 837Mhz
Time to render: 3m51s
Regards
