Activity › Forums › Adobe After Effects › AE CS6 11.0.1 CUDA BENCHMARK PROJECT – test your graphics cards!
Ian Mapleson replied 8 years, 9 months ago 94 Members · 336 Replies
Tenchi Muyo
July 24, 2014 at 6:07 pmHi Ian!
The Cards name was addded thats all ok,
i tried to underclock the 750TI but it still not work.(i found something in the internet that downclocking the gpu can help…)
https://forums.adobe.com/thread/1000794?start=0&tstart=0
Matjaz Molnar
September 6, 2014 at 2:38 pmSo I run the test without problems on:
AFX CC 2014
4930K @4,2GHz
16GB 1866MHz QuadChannel
GTX 770Result: 6 min 20 sec
This thread need more attention. People are unaware that the best card for Mercury and Ray-trace are: GTX 480, 580, 680, 780 etc.
What I mean, CPU, RAM, CUDA cores, those thing do not matter as long as the card has 384bit BUS Width or even 512bit.
192bit and 256bit are a rip-off in AFX and Premiere.
I hope that someone will do a test with the new upcomming
GTX 970 and 980, but I am not expecting much, because they have 256bit BUS width. Our only hope is the new Cuda architecture which hopefully minimizes the bandwidht limitations. -
Matjaz Molnar
September 12, 2014 at 8:53 amSo I run the test without problems on:
AFX CC 2014
4930K @4,2GHz
Ian Mapleson
September 12, 2014 at 10:58 amSorry for the long delay Tenchi, did you manage to get your card working eventually?
I was reading your post again just now, wondering if maybe the card was simpy faulty
in some way, whether you’d been able to replace it via RMA.Ian.
SGI Guru
Tenchi Muyo
September 19, 2014 at 11:10 pmHi!
I send the card back, it should be a problem with oc cards,
the msi is a oc (by deafult) card. -
Ian Mapleson
September 24, 2014 at 1:05 amNo, but I’m trying to sell two 580 3GB cards atm; if I can then I’ll replace
them with a 980 and test it.Ian.
SGI Guru
Goran Vujic
October 10, 2014 at 11:16 amI cant enable 970 GTX to work Raytracing in After Effects. Anybody can help with this issue? After editing txt file i get an error (5070::12 and 5070::0)
Ian Mapleson
October 10, 2014 at 11:57 amGoran, have you made sure the text string in the raytrace file
exactly matches the identifier string shown by GPU-Z?Ian.
SGI Guru
Cédric Thomas
October 14, 2014 at 5:21 pmMy 2cts :
4:17 on Core 2 Quad @ 2.4GHz, 4GB RAM and Asus GTX 780 3Go stock.
Soon to be replaced with i7 5820K with 32GB RAM.
