Activity › Forums › Adobe After Effects › AE CS6 11.0.1 CUDA BENCHMARK PROJECT – test your graphics cards!
Ian Mapleson replied 8 years, 9 months ago 94 Members · 336 Replies
Ian Mapleson
January 18, 2014 at 10:40 amMost likely it’s being cached somehow, or it’s rendering in Classic 3D Mode, something
like that. Just go through the settings, make sure each is as it should be, and of
course ensure all caches are cleared before starting the test (media, disk & RAM).Ian.
SGI Guru
Yakup Babalı
January 22, 2014 at 8:09 am -
Polar Films entertainment
February 14, 2014 at 4:57 pmShould I just use the test in the first post and convert the project to CC? no fidling with anything? just export out?
Michael Stephens
February 19, 2014 at 3:48 pmCorrect. Load the file, make sure you have the comp set to Ray-Traced 3D, then send the comp to the render queue.
Ian Mapleson
February 19, 2014 at 5:54 pmAnd remember to clear all memory & disk caches before
running the test. Also make sure RayTrace3D is turned on.Ian.
SGI Guru
February 28, 2014 at 7:47 pmGet in! Done in 3min 12secs!
Rig is as follows:
MOBO: ASUS P9X79E-WS
CPU: Intel i7 3930k STOCK (3.80ghz TURBO 6 core)
RAM: 64GB DDR-3 1600Mhz Kingston HyperX Gen
GFX: EVGA GeForce Titan 6GB
DRIVE1: SAMSUNG EVO 840 120GB (Windows + apps)
DRIVE2: 2xSAMSUNG EVO 840 120GB – RAID-0 (CACHE)
DRIVE3: 2xINTEL 520 240GB – RAID-0 (PROJECT- WORK)
DRIVE4: 2x WD Black 2TB – RAID-1 (STORAGE)
OS: WINDOWS 8.1MONITOR: Dell UltraSharp U3011
AUDIO: Saffire Focusrite 24 DSP Pro
SPEAKERS: 2xJBL LSR2325P
FIREWIRE: SIIG DP FireWire 800PCIe – TI XIO2213
BURNER: Lite-ON iHBS312 – BR-R+DVD+RW
COOLING: Intel Liquid Cooling Solution – RTS2011LC
CASE: Fractal Design XL R2 Black Pearl
PSU: Corsair AX1200i – 1200W
CAPTURE CARD: Blackmagic DeckLink 4K Extreme SDI
SCOPES: Blackmagic SmartScope Duo 4KUPCOMING PURCHASES:
CPU: 1x Intel Xeon E5-2697 V2
GFX: 2x EVGA GeForce GTX Titan 6GB -
February 28, 2014 at 8:30 pm -
Ian Mapleson
March 2, 2014 at 11:30 amThanks for the result!! I’m looking forward to hearing how
the test scales with the extra Titans. Also, can you run the
ArionBench test aswell? Both CPU & gfx? Would be interesting
to see how CPU performance differs to the XEON 2697 once you
have it installed.My system has the older ASU P9X79 WS (3930K @ 4.7, 4x GTX 580
3GB). How have you found your newer E-WS board in terms of
setup and usage? Any issues?Ian.
SGI Guru
March 2, 2014 at 7:58 pmHi Ian. Glad we could contribute. Regarding our current motherboard. Its great, really. Not a single crash or anything, easy to config and setup.
I reckon the bios is pretty much the same as your’s to be honest. I would advise though, to get a separate RAID controller if you have several drives, the Marvell 6Gbs controller is absolutely horrendous compared to the Intel. Even in RAID-0 the Marvell 6Gbs struggles to reach the speeds of a single drive in the Intel 6Gbs. I am absolutely clueless as to why ASUS dosent just have only Intel RAID controllers on their boards. Would be much better.But no, no issues in terms of errors. 🙂 And now yes, they added the support for the new Xeons with the latest bios update, so we can just switch over to the 2697 V2 when we want, and on that note; I will test our system with Arion now, note the results and test again when we get the extra TITANS and CPU 🙂
