Activity Forums Adobe After Effects AE CS5.5 on Sierra
  • AE CS5.5 on Sierra
    Posted by Ted Irving on July 11, 2019 at 2:22 pm
    Hello. I’m taking my staff through Mac Pro Mid2010 5,1 system updates. Painful, but necessary since they were on Final Cut 7 and OS Lion as of November 2018. All MacPro’s now run Sierra with AMD RX580 GPU’s, Davinci Resolve & FCPX. Next is SSD system drive updates. However, my motion effects editor uses AFter Effects. We chose not to go with Nvidia and we won’t be getting the current After Effects version for his Mac until later this year. Until then he needs it working and is having some issues. The error log is below. I am aware CS5 products and Sierra and above are full is issues. Wondering if CC fam has any solutions for temporary use. Thanks
    ______________________________________________________
    Process: After Effects [41466]
    Path: /Applications/Adobe After Effects CS5.5/Adobe After Effects CS5.5.app/Contents/MacOS/After Effects
    Identifier: com.adobe.AfterEffects
    Version: 10.5 (10.5)
    Code Type: X86-64 (Native)
    Parent Process: ??? [1]
    Responsible: After Effects [41466]
    User ID: 503
    Date/Time: 2019-07-10 15:33:35.811 -0500
    OS Version: Mac OS X 10.12.6 (16G29)
    Report Version: 12
    Anonymous UUID: 09FD5898-AC12-EC3C-7105-8E5B15253B0F
    Time Awake Since Boot: 1000000 seconds
    System Integrity Protection: enabled
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Exception Type: EXC_BAD_ACCESS (SIGABRT)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
    Exception Note: EXC_CORPSE_NOTIFY
    VM Regions Near 0:
    __TEXT 0000000100000000-0000000100005000 [ 20K] r-x/rwx SM=COW /Applications/Adobe After Effects CS5.5/Adobe After Effects CS5.5.app/Contents/MacOS/After Effects
    Application Specific Information:
    abort() called
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0 libsystem_kernel.dylib 0x00007fffbdcd2d42 __pthread_kill + 10
    1 libsystem_pthread.dylib 0x00007fffbddc0457 pthread_kill + 90
    2 libsystem_c.dylib 0x00007fffbdc38420 abort + 129
    3 U.dylib 0x0000000102ebe8b7 U_LoadFrameworkBundle + 663
    4 com.adobe.dvacore.framework 0x00000001032e5b84 (anonymous namespace)::SignalHandler(int, __siginfo*, void*) + 788
    5 libsystem_platform.dylib 0x00007fffbddb3b3a _sigtramp + 26
    6 ??? 0x4031000000000000 0 + 4625478292286210048
    7 com.adobe.AfterEffectsLib.framework 0x0000000100ac9fe1 CTopicArray::Iterate(short, void*) + 337
    8 com.adobe.AfterEffectsLib.framework 0x0000000100907e47 CLayer::ScrubStream(COutlinePano*, int, TDB_StreamIDPath const&, unsigned char, Point) + 1927
    9 com.adobe.AfterEffectsLib.framework 0x0000000100c22a88 CRQRenderSettings::SetRS_FromPref(int) + 258008
    10 com.adobe.AfterEffectsLib.framework 0x0000000100bfe544 CRQRenderSettings::SetRS_FromPref(int) + 109204
    11 com.adobe.AfterEffectsLib.framework 0x0000000100bfbadf CRQRenderSettings::SetRS_FromPref(int) + 98351
    12 com.adobe.AfterEffectsLib.framework 0x0000000100c205c5 CRQRenderSettings::SetRS_FromPref(int) + 248597
    13 com.adobe.AfterEffectsLib.framework 0x0000000100abcb03 COutlineDir::GetOutlinePano() + 30947
    14 com.adobe.AfterEffectsLib.framework 0x0000000100abf1ca COutlineDir::GetOutlinePano() + 40874
    15 com.adobe.AfterEffectsLib.framework 0x0000000100b910f1 CTLOutlinePano::CenterCurrentTimeIfNecessary() + 6481
    16 com.adobe.AfterEffectsLib.framework 0x0000000100767129 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 393
    17 com.adobe.AfterEffectsLib.framework 0x0000000100767044 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
    18 com.adobe.AfterEffectsLib.framework 0x0000000100767044 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
    19 com.adobe.AfterEffectsLib.framework 0x0000000100795218 dvacore::utility::SearchLiveHelp(std::basic_string) + 7208
    20 com.adobe.AfterEffectsLib.framework 0x0000000100ab51de GetCEffects(BEE_Layer*) + 77582
    21 com.adobe.dvaui.framework 0x00000001036f1802 dvaui::ui::UI_Node::UI_DispatchMouseEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 146
    22 com.adobe.dvaui.framework 0x00000001036f47b5 dvaui::ui::UI_Node::DispatchMouseEvent::operator()(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvacore::geom::PointT const&) const + 165
    23 com.adobe.dvaui.framework 0x00000001036fe173 std::pair dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT const&, bool) + 131
    24 com.adobe.dvaui.framework 0x00000001036f86e3 dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeaf(dvaui::ui::MouseEvent const&, bool) + 83
    25 com.adobe.dvaui.framework 0x00000001036f9e2f dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&, bool) + 159
    26 com.adobe.dvaui.framework 0x00000001036f9f14 dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 68
    27 com.adobe.dvaui.framework 0x000000010376b633 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 595
    28 com.adobe.dvaui.framework 0x0000000103767419 dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 313
    29 com.adobe.dvaui.framework 0x000000010376daa2 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 450
    30 com.adobe.dvaui.framework 0x00000001037584df dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 31
    31 com.adobe.dvaui.framework 0x000000010375e1fb dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 59
    32 com.adobe.dvacore.framework 0x00000001031f7376 int dvacore::config::ErrorManager::ExecuteFunction(boost::function0*, void*) + 38
    33 com.adobe.AfterEffectsLib.framework 0x00000001006f6f96 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5382
    34 com.adobe.AfterEffectsLib.framework 0x00000001006f70c1 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5681
    35 com.adobe.dvacore.framework 0x00000001031f5f15 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0, bool*) + 197
    36 com.adobe.dvacore.framework 0x00000001031f8ab3 void dvacore::config::ExecuteTopLevelFunction(boost::function0, bool*) + 99
    37 com.adobe.dvaui.framework 0x00000001037614bd -[DVAMacContainerView mouseDown:] + 253
    38 com.apple.AppKit 0x00007fffa63d324f -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 6341
    39 com.apple.AppKit 0x00007fffa63cfa6c -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 1942
    40 com.apple.AppKit 0x00007fffa63cef0a -[NSWindow(NSEventRouting) sendEvent:] + 541
    41 com.apple.AppKit 0x00007fffa6253681 -[NSApplication(NSEvent) sendEvent:] + 1145
    42 com.adobe.dvaui.framework 0x0000000103759ebf -[DVAMacApplication sendEvent:] + 223
    43 com.adobe.AfterEffectsLib.framework 0x00000001004ffa73 0x1004b1000 + 322163
    44 com.apple.AppKit 0x00007fffa5ace427 -[NSApplication run] + 1002
    45 com.adobe.AfterEffectsLib.framework 0x000000010074a6a2 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 15826
    46 com.adobe.AfterEffectsLib.framework 0x00000001006f5377 SetAPETerminateFunc(boost::function const&) + 1399
    47 com.adobe.AfterEffectsLib.framework 0x00000001006f5ae4 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 84
    48 com.adobe.AfterEffects 0x0000000100004408 main + 1144
    49 com.adobe.AfterEffects 0x0000000100003d39 _start + 227
    50 com.adobe.AfterEffects 0x0000000100003c55 start + 33
    Thread 1:
    0 libsystem_kernel.dylib 0x00007fffbdcd2bf2 __psynch_cvwait + 10
    1 libsystem_pthread.dylib 0x00007fffbddbe7fa _pthread_cond_wait + 712
    2 com.adobe.amt.services 0x0000000112f45247 C_AMTUISwitchSuppressUpdates + 16439
    3 com.adobe.amt.services 0x0000000112f3e39e C_EULA_SetState + 1742
    4 com.adobe.amt.services 0x0000000112f452b2 C_AMTUISwitchSuppressUpdates + 16546
    5 libsystem_pthread.dylib 0x00007fffbddbd93b _pthread_body + 180
    6 libsystem_pthread.dylib 0x00007fffbddbd887 _pthread_start + 286
    7 libsystem_pthread.dylib 0x00007fffbddbd08d thread_start + 13
    Thread 2:
    2 com.apple.CoreServices.CarbonCore 0x00007fffa8f3379d TSWaitOnCondition + 108
    3 com.apple.CoreServices.CarbonCore 0x00007fffa8f3399c TSWaitOnConditionTimedRelative + 171
    4 com.apple.CoreServices.CarbonCore 0x00007fffa8f0cb20 MPWaitOnQueue + 192
    5 com.adobe.dvacore.framework 0x000000010325c8cf dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 143
    6 com.adobe.dvacore.framework 0x00000001031f8b8e boost::function0::operator()() const + 46
    7 com.adobe.dvacore.framework 0x0000000103254dd3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 99
    8 com.adobe.boost_threads.framework 0x0000000108d19744 thread_proxy + 132
    9 libsystem_pthread.dylib 0x00007fffbddbd93b _pthread_body + 180
    10 libsystem_pthread.dylib 0x00007fffbddbd887 _pthread_start + 286
    11 libsystem_pthread.dylib 0x00007fffbddbd08d thread_start + 13
    Thread 3:
    Thread 4:
    Thread 5:
    Thread 6:
    5 com.adobe.ACE 0x0000000109cbaa5d 0x109c80000 + 240221
    6 com.adobe.ACE 0x0000000109cba40a 0x109c80000 + 238602
    7 com.apple.CoreServices.CarbonCore 0x00007fffa8f0cf34 PrivateMPEntryPoint + 39
    8 libsystem_pthread.dylib 0x00007fffbddbd93b _pthread_body + 180
    9 libsystem_pthread.dylib 0x00007fffbddbd887 _pthread_start + 286
    10 libsystem_pthread.dylib 0x00007fffbddbd08d thread_start + 13
    Thread 7:
    Thread 8:
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    Thread 13:
    Thread 14:
    Thread 15:
    Thread 16:
    Thread 17:
    Thread 18:
    Thread 19:
    Thread 20:
    Thread 21:
    5 com.adobe.ASLFoundation.framework 0x00000001055d0c60 ASL::(anonymous namespace)::TaskProc(void*) + 96
    6 com.apple.CoreServices.CarbonCore 0x00007fffa8f0cf34 PrivateMPEntryPoint + 39
    7 libsystem_pthread.dylib 0x00007fffbddbd93b _pthread_body + 180
    8 libsystem_pthread.dylib 0x00007fffbddbd887 _pthread_start + 286
    9 libsystem_pthread.dylib 0x00007fffbddbd08d thread_start + 13
    Thread 22:
    Thread 23:
    Thread 24:
    Thread 25:
    0 libsystem_kernel.dylib 0x00007fffbdcd3d96 kevent + 10
    1 com.adobe.dvatransport.framework 0x0000000108a35a6e boost::asio::detail::kqueue_reactor::run(bool) + 478
    2 com.adobe.dvatransport.framework 0x0000000108a36b25 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 517
    3 com.adobe.dvatransport.framework 0x0000000108a13bbc SkyConnectionEnv::MainLoop() + 76
    4 com.adobe.dvatransport.framework 0x0000000108a13c29 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
    5 com.adobe.boost_threads.framework 0x0000000108d19744 thread_proxy + 132
    6 libsystem_pthread.dylib 0x00007fffbddbd93b _pthread_body + 180
    7 libsystem_pthread.dylib 0x00007fffbddbd887 _pthread_start + 286
    8 libsystem_pthread.dylib 0x00007fffbddbd08d thread_start + 13
    Thread 26:
    2 com.adobe.dvatransport.framework 0x0000000108a36c5f boost::asio::detail::task_io_service::run(boost::system::error_code&) + 831
    3 com.adobe.dvatransport.framework 0x0000000108a37855 boost::asio::detail::posix_thread::func::run() + 53
    4 com.adobe.dvatransport.framework 0x0000000108a1c7a9 asio_detail_posix_thread_function + 25
    Thread 27:
    2 com.adobe.ImporterCinemaDNG.framework 0x000000011c5111d5 dng_condition::Wait(dng_mutex&, double) + 245
    3 com.adobe.ImporterCinemaDNG.framework 0x000000011c49e227 cr_scratch_thread::Task() + 87
    4 com.adobe.ImporterCinemaDNG.framework 0x000000011c34b40a TaskGlue + 10
    Thread 28:
    2 com.adobe.AfterEffects.MThread 0x000000011d8486cf main + 21151
    3 com.adobe.dvacore.framework 0x00000001031f8b8e boost::function0::operator()() const + 46
    4 com.adobe.dvacore.framework 0x0000000103254dd3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 99
    Thread 29:
    Thread 30:
    Thread 31:
    Thread 32:
    Thread 33:
    Thread 34:
    Thread 35:
    Thread 36:
    Thread 37:
    Thread 38:
    Thread 39:
    Thread 40:
    Thread 41:
    Thread 42:
    Thread 43:
    Thread 44:
    2 com.adobe.AfterEffects.OpenEXR 0x0000000121026484 IlmThread::Semaphore::wait() + 100
    3 com.adobe.AfterEffects.OpenEXR 0x0000000121025546 IlmThread::(anonymous namespace)::WorkerThread::run() + 182
    4 libsystem_pthread.dylib 0x00007fffbddbd93b _pthread_body + 180
    5 libsystem_pthread.dylib 0x00007fffbddbd887 _pthread_start + 286
    6 libsystem_pthread.dylib 0x00007fffbddbd08d thread_start + 13
    Thread 45:
    Thread 46:
    Thread 47:
    Thread 48:
    Thread 49:
    Thread 50:
    Thread 51:
    Thread 52:
    Thread 53:
    Thread 54:
    Thread 55:
    Thread 56:
    Thread 57:
    Thread 58:
    Thread 59:
    Thread 60:
    0 libsystem_kernel.dylib 0x00007fffbdcd2f46 __semwait_signal + 10
    1 libsystem_c.dylib 0x00007fffbdc59b72 nanosleep + 199
    2 com.adobe.AfterEffects.Scripting 0x000000012194004b zcfree + 197985
    3 com.adobe.AfterEffects.Scripting 0x0000000121923063 zcfree + 79225
    4 com.adobe.AfterEffects.Scripting 0x0000000121940146 zcfree + 198236
    Thread 61:
    2 com.adobe.adobeswfl 0x00000001223c7ced APXGetHostAPI + 2467693
    3 com.adobe.adobeswfl 0x000000012217fd09 APXGetHostAPI + 75657
    4 com.adobe.adobeswfl 0x00000001223c7e01 APXGetHostAPI + 2467969
    5 com.adobe.adobeswfl 0x00000001223c816a APXGetHostAPI + 2468842
    6 com.adobe.adobeswfl 0x00000001223c8299 APXGetHostAPI + 2469145
    Thread 62:
    Thread 63:
    Thread 64:
    Thread 65:
    Thread 66:
    Thread 67:
    Thread 68:
    Thread 69:
    1 libsystem_pthread.dylib 0x00007fffbddbe833 _pthread_cond_wait + 769
    2 com.adobe.adobeswfl 0x00000001223c7cb9 APXGetHostAPI + 2467641
    3 com.adobe.adobeswfl 0x00000001223e406c APXGetHostAPI + 2583276
    Thread 70:
    3 com.adobe.adobeswfl 0x0000000122562573 APXGetHostAPI + 4149235
    Ted Irving replied 7 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
