Activity Forums Adobe After Effects AE CS5.5 3D question
  • AE CS5.5 3D question
    Posted by Richard Chenoweth on April 22, 2012 at 1:36 pm
    When I animate a Camera around a 3D Layer: Sometimes the Camera’s next keyframe position has Bezier
    curves in both directions, and sometimes the Camera’s next keyframe position switches to a straight
    line and does not have Bezier curves.
    What’s the difference here? Is there a way to always have Bezier curves? Does AE leave them
    out if there is too much interpolated movement?
    Thanks for any help!
    Rich
    Erik Waluska replied 14 years, 5 months ago 2 Members · 1 Reply
  • Erik Waluska
    April 22, 2012 at 3:38 pm
    You can set the default keyframe interpolation in the general preferences by checking or unchecking “default spatial interpolation to linear” and AE will always create new keyframes with that interpolation.
    Bezier handles are only visible on selected keyframes in both the graph editor and the comp window, so unselected keyframes may appear to be linear. Also, bezier handles can be very hard to see in the comp window, even on selected keyframes, when the animation path is straight instead of curved because the handle perfectly lines up with the path and the only indication it’s there is a slightly larger dot along the path that indicates the end of the handle.
    HTH
