Activity Forums Adobe After Effects AE CS5 – setting Audio Hardware to SYSTEM DEFAULT does not do what you want it to
  • AE CS5 – setting Audio Hardware to SYSTEM DEFAULT does not do what you want it to
    Posted by Rob Larose on June 29, 2011 at 7:12 pm
    I’ve submitted this as a bug to Adobe already, but wondered if anyone here has experienced it?
    In AE CS5 on OSX, if I set the Audio Hardware pref to System Default (so we just follow the OSX system audio output device), we’ll often get a hang followed by an error – can’t start audio playback.
    I wind up having to set the audio output device directly in AE Prefs. That seems to work fine. So if I’ve got SPEAKER 1 selected in the system prefs, and I choose System Default in AE, it won’t work. When I then select SPEAKER 1 directly in AE, it works.
    Seems like a bug, but I reported in April and heard nothing from ’em.
    Anyone have any ideas?
    Rob Larose replied 15 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
