Activity Forums Adobe After Effects AE CS5 render error
  • AE CS5 render error
    Posted by Noah Klersfeld on January 7, 2011 at 9:34 pm
    I am rendering an after effects project in CS5 and 3 hours into the 30 hour render it displays the following message “after effects warning: logged one error – error: an output module stopped responding. the file may be damaged or corrupted. you may need to restart after effects”. I restarted, re-rendered and the same message displayed at approximately the same time into the program. Does anyone have any experience with this error message? I have MacPro from 2006 running snow leopard OS.
    Noah Klersfeld replied 15 years, 7 months ago 2 Members · 10 Replies
  • 10 Replies
  • Noah Klersfeld
    January 7, 2011 at 9:56 pm
    the render simply stops rendering. i have reviewed the source footage and it plays through with no problems. i was looking at an old post of yours…Is it possible that it is failing because I have 2GB of RAM and my project has 500 video layers of HDV? I am on a dual core 2x3GHz processor…Do you think purchasing a 12 core machine with maximum RAM could solve this problem? Thanks for responding to my post.
  • Noah Klersfeld
    January 7, 2011 at 10:49 pm
    Thank you dave for your comments. I really appreciate them. What is hyperthreading?
  • Brian Charles
    January 8, 2011 at 12:19 am
    Dave is right, however you *may* be able to render if you change how frequently memory is purged during render.
    To do this you need to access the “Secret Preferences” and change how frequently memory is purged.
    To access the Prefs you hold down the Shift key on your keyboard while choosing Preferences>General from the menu.
    See:
    Secret_Prefs
  • Noah Klersfeld
    January 8, 2011 at 4:58 pm
    thank you Brian. I will try this in the interim and let you know if it works.
  • Noah Klersfeld
    January 8, 2011 at 5:01 pm
    thanks dave. when specifying a new machine does the graphics card play a role in the rendering? how about solid state drives?
  • Brian Charles
    January 8, 2011 at 11:10 pm
    The graphics card plays no significant role in rendering. OpenGL is troublesome in After Effects, it can speed some aspects of 3D previews such as lights and shadows, and while it is possible to render an OpenGL preview, its not recommended since quality suffers.
    As for SSD’s they are great for speedy launch of applications (I have one as a boot drive on my MacPro) but do nothing at all for renders. Render and preview speeds are primarily affected by processor speed ,number of processors, and RAM. The more of all the better. That said, some effects, footage and comps are computationally more expensive than others and will render
    I’m currently on a 12 core MacPro with 32 GB of RAM. Previously I was on an 8 core with 16GB. Subjectively measured, the 12 core is about 30% faster than the 8 core. I haven’t bothered to do rigorous testing.
  • Brian Charles
    January 8, 2011 at 11:11 pm
    As for SSD’s they are great for speedy launch of applications (I have one as a boot drive on my MacPro) but do nothing at all for renders. Render and preview speeds are primarily affected by processor speed ,number of processors, and RAM. The more of all the better. That said, some effects, footage and comps are computationally more expensive than others and will render more slowly.
  • Noah Klersfeld
    January 12, 2011 at 12:29 pm
    Thank you
  • Noah Klersfeld
    January 12, 2011 at 4:59 pm
    Thank you
  • Noah Klersfeld
    January 23, 2011 at 7:43 pm
    When purchasing a new machine i have been reading that for RAM the best strategy is to get the minimum factory installed by apple, buy 64G from third party suppliers and swap out the apple RAM entirely for the third party RAM. Would you agree? Thank you
