Activity Forums Adobe After Effects AE cs5 project window display problem
  • AE cs5 project window display problem
    Posted by Brian Mills on January 28, 2011 at 3:53 pm
    Hey all
    I have a problem when I move a layer using the numbers under the parameter(Pos,scale)the display comp window does not show it moveing until I stop adjusting the numbers. ive tried tunign off openGL and adaptive res but nothing works…this also accurs when i am trying to use the 3d camera and particular. If I grab a layer and move it on the comp display the object gos into wire mode instead of keeping the original
    Ive got a Quadro 2000 open GL card and Ive updated the drivers Any help would be appreciated
    Brian
    Brian Mills replied 15 years, 6 months ago 2 Members · 2 Replies
  • Joey Foreman
    January 28, 2011 at 3:59 pm
    Joey Foreman
    Editor/Compositor/VFX Artist
  • Brian Mills
    January 28, 2011 at 4:00 pm
    Thank you…man only been doing this for 15 years…think i would have been able to figure that out…LOL
    thanks again!
