Activity Forums Adobe After Effects AE CS5 patch renders are sloooooooow
  • AE CS5 patch renders are sloooooooow
    Posted by Dester Wallaboo on August 27, 2010 at 4:25 pm
    OK….. so I have a pretty beefy machine. But this problem doesn’t have to do with my machine, but with the way CS5 has changed the way it looks at comps. In CS4, if I needed to make a quick patch, I could place the previously fully rendered file on the top of the comp. Knock a hole where my change/patch needed to take place, and then render it off again. CS4 would clip along at a fast pace…. ignoring all the layers below the top rendered file. As it should. However… CS5 has gone backwards and no longer ignores the layers below the rendered QuickTime. Even though there are no alpha holes or the like. Just a solid rendered QuickTime.
    Erik Lindahl replied 16 years ago 2 Members · 3 Replies
  • Dester Wallaboo
    August 27, 2010 at 4:33 pm
    Nope… it doesn’t work… same issue… it looks at everything. Definitely a new CS5 bug.
  • Dester Wallaboo
    August 27, 2010 at 4:46 pm
    Nope… no changes…. nothing. It makes no difference. I’ve tried this on multiple projects with the same result in CS5.
  • Erik Lindahl
    August 27, 2010 at 11:46 pm
    This is odd. From my experience AE CS5 handles re-renders / caching WAY better than CS4.
    Erik Lindahl
    Freecloud Post Production Services
    http://www.freecloud.se
