Activity Forums Adobe After Effects [AE CS5] 3D Projection Camera
  • [AE CS5] 3D Projection Camera
    Posted by Duca Simone luchini on March 24, 2011 at 2:29 pm
    Hello everyone,
    following some tutorials on the web about the 3D camera projection in Ae,
    for example https://www.videocopilot.net/tutorial/3d_camera_projection/ [from minute 06:28]
    it always comes to a point where you have to copy the Camera Position parameters in those o f a duplicated original Photo that usually is renamed “Projected”.
    At this point there is a passage that I can’t understand: that Photo named “Projected” is first approaching repositioned using the Z Position parameter, but re scaled by Scale parameters to resize for the general framework of the Comp…
    I do not understand this step: why and how many heve i move Z parameters in Position and why heve i change paramenters (going to Scale) to finish resizing for the general framework of the Comp?
    Hard to explain but if you see the tutorial you’ll know what I mean.
    Many, many thanks!
    Juan Urquhart replied 15 years, 5 months ago 2 Members · 1 Reply
  • Juan Urquhart
    March 25, 2011 at 7:59 pm
    Hi Maurito,
    that’a good question , the idea is to place the picture to be projected just in front of the camera, that’s why you have to reposition it using z parameter… that can be done by eye, is not necesary to be exact…so the advice is to look at the comp from the top view, you’ll see the projection camera, the projection light and the picture… then you look from the active camera , and scale the picture until the projection recovers the original size…
    hope it makes sense
