Activity Forums Adobe After Effects AE CS4 Render fail
  • AE CS4 Render fail
    Posted by Joonas Ee on March 25, 2010 at 12:02 am
    Hi!
    I know there is lot of posts about this problem but any of those havent helped me out yet.
    So my ae cs4 render fails everytime in a same spot.
    I have tried the purge every 20 frame but that didnt work. And im sure that there is not openGL on on the render prefs.
    What could be the problem? How about changing the purge frame amount to something else? What should i try 2frame 80frame?
    I have noticed that the ram usage is around 60%-65% when it fails.
    There isnt any heavy effects on the timeline where the fail happend. Just some magic bullet look.
    Any help would be great!
    Bruce Wainer replied 16 years, 5 months ago 2 Members · 1 Reply
  • Bruce Wainer
    March 26, 2010 at 1:00 am
    I can’t help you with your problem exactly, but try rendering to an image sequence (TIFF, TARGA, PNG, etc.) so that after it fails, you can re-render with the ‘skip existing frames’ option selected. This will skip the frames that rendered successfully, allowing you to continue where you left off. Eventually your project should be completed (if it fails on the first frame when you re-start, then you know something’s up with that particular frame. We’ve got a video that won’t burn completely to disc in Encore, and it always stops on the same frame).
