AE CS4 randomly skipping frames when ram previewing
Hello everybody,
I desperately need some help here, please let me know if I’m doing something wrong,
I have a bunch of .mts files that my client sent me via ftp and I’m editing them on Premiere Pro CS4, the files open fine without any need of converter or anything.
Occasionally I need to track some shots so I can stabilize them or add a title plate to them, nothing fancy, 3 or 4 seconds each time at most, so I sent the clip to AE from Premiere in order to only get the part I need rather than the entire clip. So far, so good.
I first tracked with AE built in tracker, and I noticed a couple, maybe three abrupt jumps, so I fixed the tracking manually, then I added a null object and a text parented to it and that’s when I noticed the jerky movement I was getting, as if the file was being interpreted with the wrong filed order, I changed the filed from upper (automatically detected by AE) to lower, turns out upper was right, I got really jerky movement, so I went back to upper, then I thought that maybe the codec was playing tricks on me so I rendered my comp in a number of formats, .mov, .tif, .png. and .tga sequences. I checked the frames on Photoshop and everything looked fine, yet when I imported them back in Ae to track over those again I got the jumps, three or four almost at the end. I played the ram preview frame by frame and I was able to isolate the frames, there were 4 of them only, and they were not being skipped, So I ram previewed up to one frame before the jump happened and everything fine. I ram previewed again with the full work area selected and the jumps are there.
My guess (and I’m no expert at all) is that I got a faulty video card (I got a late 2008 macbook pro with 4 gigs, 2.8ghz and read about some defective video cards made by Nvidia installed on those) but I want to be sure first, any help will be greatly appreciated, I’m under a bit of a deadline here and I tried pretty much everything.
Thanks in advance,
D.
