Activity Forums Adobe After Effects AE CS4 ram management problem
  • AE CS4 ram management problem
    Posted by Frank Ruggiero on April 22, 2010 at 10:03 pm
    Hi Cow Experts.
    My problem is AE CS4. I recently upgraded. I never had any issues with CS3 managing ram, so I feel confident it is a CS4 problem.
    The problem being for instance, I can work on a spot and for a short amount of time, Ram previews work fine. But the more I work on it, all of the sudden, I will only be able to preview a couple of seconds. Then I have to purge ram in order to get a full preview, and then the same thing happens. I work, and make a couple of changes, and then I am can only preview a little bit at 1/4 resolution.
    Sometime it says something like “After Effects needs more than 2 frames for a ram preview” and I have to purge. It is so frustrating that I went back to working in CS3.
    Anyone have this problem. Its really disappointing.
    Thanks in advance.
    FR
    Frank Ruggiero replied 16 years, 5 months ago 2 Members · 3 Replies
  • Frank Ruggiero
    April 23, 2010 at 4:55 am
    Hi Dave,
    Thank you for taking the time to respond. I was hoping you were on to something, however I am updated to 9.02.42…
    ANyone else have this problem? I am the only one with this conflict? Any ideas?
    Maybe I will have to make the move to CS5 and hope for the best.
    Frank
  • Serge Hamad
    April 23, 2010 at 5:48 am
    Hi Frank,
    Deleting your AE’s prefs file should do the trick. The “At least 2 frames…” warning used to happen a lot in version 7.0, less in CS3 & CS4. And deleting the prefs always helped us.
    Just try it and let us know.
    Salut.
    Serge
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • Frank Ruggiero
    April 23, 2010 at 3:02 pm
    Hi Serge,
    Thank you for responding. That looks like it fixed my problem! I went back to a problematic project, and kept shifting things around, doing ram previews and it was able to preview the whole 15 second timeline at full resolution. I never considered rebuilding the preference file. Thanks again for your help.
    -Frank
