Activity Forums Adobe After Effects AE CS4 on Windows XP x64
  • AE CS4 on Windows XP x64
    Posted by Lance Fallon on August 7, 2009 at 1:56 am
    I just upgraded my pc with an intel i7 920 quad-core processor & will have 12 GB of RAM, and i’m trying to decide what OS to buy.
    And i was wondering if anyone here uses XP 64-bit with AE CS4?? And if so, is After Effects CS4 able to gain the same advantage on XP 64, as it does on Vista 64 (i.e., use the quad-core processor for multiprocessing, and utilize most of my RAM)? Or would i be better off going with Vista 64?? I also noticed on Adobe’s site that CS4 isn’t “certified” on XP 64-bit.
    Lance
    Joseph W. bourke replied 17 years, 1 month ago 4 Members · 5 Replies
  • Todd Kopriva
    August 7, 2009 at 5:53 am
    I am happily using 64-bit Windows Vista (though I’m typing this on my Mac). After Effects CS4 is not officially supported on 64-bit Windows XP.
    Some people who know more than I do about this kind of thing have suggested that the upgrade path to Windows 7 will be less painful from Vista.
    None of this is a recommendation one way or the other. I’m just giving you a few facts and thoughts.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Lance Fallon
    August 7, 2009 at 7:32 pm
    It sounds like going with Vista 64 over XP64 might be a bit safer… It’ll probably be supported longer as well.
  • Joseph W. bourke
    August 8, 2009 at 12:53 am
    Here’s my two cents (only worth one cent these days). I just had a system configured around an Intel motherboard (core 2 extreme), running CS4 on Vista 64. No scientific study here, but a project, which I rendered on Windows XP Pro on a 3.0GHz single processor with 4MB of RAM, went like this:
    It took one hour and fifty-four minutes to render a project (lots of layers, several effects) on the XP box. The identical project took seven minutes to render on the dual quad machine with Vista 64 bit. Needless to say, I was astounded!
    As I say, this is nothing scientific – no benchmarks here – and no desire other than to increase my speed of workflow and efficiency, which this new box has done in spades!
    Joe Bourke
    Creative Director / B&S Exhibits and Multimedia
  • Scott Roberts
    August 8, 2009 at 4:37 am
    Wow, Joe! That’s quite a difference in speed! What are the specs on your XP box?
    I’ve been thinking about 64 bit, but not a lot of people I know are utilizing it. On my Mac at work – which is 64 bit, AE seems to feel about the same speed as my XP 32-bit machine at home.
  • Joseph W. bourke
    August 8, 2009 at 3:28 pm
    Hi Scott –
    Yeah, I was pretty shocked at the difference in render times – as I said this was not scientific, but it WAS done with identical projects in which I had collected all the files, so the playing field seemed even to me.
    My new system, which I had configured by a local shop here in NH, for about 1600 bucks, consists of this:
    Intel Motherboard – DP45SG – this has an ESATA connector for a RAID
    Quad Core2 Q9550, 2.83GHz, 1333MHz, L2 12M
    8GB of PC3-10600 CL9 DDR3 240p DIMM RAM
    GEForce GTX 260 – EVGA graphics card
    2 – 500GB Seagate SATA2 7200rpm hard disks – one for OS, one for Applications
    2 – 750GB 7200rpm 32mb SATA2 hard drives – for media files – this is NOT striped – at some point I will probably add a RAID array for doing HD – I haven’t tried editing true HD on this pup yet
    600watt silent fan power supply – this thing is really quiet – I can probably do audio recording in the same room with this running.
    Case – X-Cruiser Black system chassis – this is a gamer case with plenty of room for expansion.
    That’s about it, other than that it’s running Vista Business 64-bit. I was originally going to go with XP Pro 64-bit, but I think the upgrade path to Win7 will be smoother, plus Adobe recommends Vista 64 for the CS4 production bundle, and so far, I can see why. This thing screams! I just loaded 40 minutes of cloud footage I shot yesterday in 1080i; it loaded fine in .mts (Canon native format) format into AE, and I was able to speed it up 2000 times, giving me a really nice, smooth time-lapse effect, without the usual light stutter you get when you use the intervalometer setting on a camera. It will render about one and a half minutes or better to RAM with the current 8MB of RAM.
    Hope this helps.
    Joe Bourke
