Activity Forums Adobe After Effects AE CS4 not saving project correctly on closing
  • AE CS4 not saving project correctly on closing
    Posted by Steven Monk on June 22, 2011 at 1:03 pm
    Bit of an odd one this but my AE CS4 has a wierd glitch.
    When i save a project and then quit AE it somehow doesn’t save properly. I don’t know how else to describe it. If i save my project then choose close project then quit, the save file is fine, but if i save, then quit without closing the project first, the save file reverts back to an earlier version.
    Anyone else ever had this problem or know how to fix it? gets a bit annoying when i’ve done a load of work then forget to hit close project first!
    Thanks in advance
    Steve
    Brian Charles replied 15 years, 2 months ago 2 Members · 1 Reply
  • Brian Charles
    June 22, 2011 at 10:24 pm
    This is indeed weird. Perhaps corrupt preferences?
    Mac OS : To reset AE prefs to their defaults hold down the Command+Shift+Option keys as you launch the application.
    Windows: To reset AE prefs to their defaults hold down the Control+Shift+Alt keys as you launch the application.
