Activity › Forums › Adobe After Effects › AE CS4 Hanging up during a RAM Preview – Mac Pro
  • AE CS4 Hanging up during a RAM Preview – Mac Pro
    Posted by Jonathan Cutrell on May 21, 2009 at 5:08 am
    Here are the specs:
    AE CS4 9.0.1
    Mac OS 10.5.7
    Quicktime Pro 7.6 (just for info)
    2×2.8 Quad-Core Intel Xeon
    10GB 800 MHz DDR2 FB-DIMM
    NVIDIA GeForce 8800 GT
    Memory/multiprocessing settings
    Got a disk cache set up too.
    At this point, I’ve disabled anything that would normally take the processing power… images, lights, motion blur, etc. There should be absolutely NO reason this should be taking so long to ram preview. I went down to quarter res, OpenGL is off, skipping frames. Still hangs. It’s at 720p. All the shapes are done internally in after effects. Only two comps, really, are referenced. They have comps inside them, but seriously. This computer should be handling this. What’s the deal?
    Kevin Camp replied 17 years, 4 months ago 2 Members · 1 Reply
  • Kevin Camp
    May 21, 2009 at 3:11 pm
    i’m not completely sure about what you mean by hanging… does it hold for a bit then start rendering, or is the mouse pointer turning into the spinning beach ball of death and ae completely stops responding, forcing you to do a force quit to get out of ae?
    just a few quick notes on your settings… it’s a little unclear in the ae docs about this, but since the minimum ram for os10.5 is 512mb, you may want to leave at least .5gb for the os in the ‘ram to leave for other applications’ setting….
    you might also try pushing the longer preview/faster rendering slider back towards faster rendering a bit. this leaves more ram for processing, which may help you out some.
    have you tried disabling the multiprocessing option and disk cache… multiprocessing can sometimes get a little buggy. and you didn’t mention that you had external storage for media/renders, disk cache will often have a negative effect on performance if you are using it with only one drive bus (like the internal drive bus).
    if you’re still not having any luck, you might try pulling the preference folder to the desktop and restart ae. find the folder called ‘9.0’ in users/username/library/preferences/adobe/after effects and move it to the desktop. when you restart ae, all those files will be recreated and ae will be reset to it’s default state. try a ram preview while ae is in that state to see if you still have the hanging problem.
    also, did you have any problems prior to installing osx 10.5.7…? i haven’t heard too much about 10.5.7 causing issues with ae… but there is a possibility that it could have caused a problem. you should also do a repair permissions after a system update (applications>utilities>disk utility, select boot drive and click repair permissions)… it may not help this issue, but it’s good practice…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
