Activity Forums Adobe After Effects AE CS4 drops frames when rendering..
  • AE CS4 drops frames when rendering..
    Posted by Melissa Kern on July 1, 2009 at 4:09 pm
    Hi.
    I am rendering a composition that contains 4 layers total. 2 pre-rendered Quicktimes (DV Quality), 1 audio mp3, and a black solid.note: 1 Quicktime is time remapped. I have a Mac Pro with 8 processors and 10 gigs. I am using multi-processing (I use 4 of the 8 processors and I allow 1 gig per processor).
    the entire composition is 3 and 1/2 min.
    I keep trying to get a “clean render”.. and each time a section of the render starts dropping frames (the screen goes completely black)..more than a “flicker” ..so not just a single frame.
    and..its not always at the same point. it changes each time I try and render.
    any suggestions? I’ve been hunting the forums and haven’t really come up with anything.
    thanks
    m
    Melissa Kern replied 17 years, 1 month ago 29,107 Members · 2 Replies
  • Melissa Kern
    July 1, 2009 at 5:38 pm
    I tried to render not using multi processing and I got this error message.
    after effects error: updating movie-out of memory (-108)
    (44::53)
    and something really strange happened… there was a box outside of the composition playback window – on the desktop itself- of the video I am trying to render..and when I would scrub the timeline that “box” scrubs right along with the composition window…does that seem video card related?
    finally, I did shoot some of the footage originally in HD but then out put still images from that as .psd and created animations from those .psd
    thanks for responding I will try an .aiff file if I can find it oor convert what I have.
  • Melissa Kern
    July 20, 2009 at 10:50 pm
    Hi..
    I’ve solved my problem by rendering out the animation as a targa sequence.
    is there a program you could suggest for combining the sound (which is a mp3) and the targa
    sequence? I have FCP, but don’t want any loss in image quality…I also have CS4..with the adobe encoder.
    and premiere of course.
    my final output is for the web (still 720×480 though)..what the best way to render for the web?
    can I change an mp3 to an aif?
    any suggestion would be a great help.
    thanks
    m
