AE CS4 and P2 – best options to get them to play nice…?
Medium-time reader; first time questioneer….
I’ve recently upgraded to CS4 from AE7, and have noticed that there is a handy new preset for DVCProHD 720 23.976 in the composition settings window. Trouble is, the comp comes up as a technically-accurate 960×720 comp with a par of 1.33. Obviously, for any VFX work, this isn’t an ideal working space.
I’ve dealt with this issue in the previous version of AE by any number of noodlings with comp par, footage par, and setting my comp size to 1280×720. And, generally speaking, I tend to use the raw QT files pulled from the HVX-200 rather than exporting from FCP. (I’ve found that when exporting DVCProHD footage from FCP to use in AE, there’s an image quality hit, regardless of whether I use ‘export’ or ‘export using quicktime conversion.’)
So, my workflow has been:
Import QT file (from camera ‘raw’ footage on HD) into AE.
Setup a custom 1280×720 comp at 23.978 (square pix).
Bring QT footage into comp, (either adjusting via ‘interpret footage’ or simply doing a x-scale to fit.)
Apply VFX.
Render footage using a custom output module that stretches the footage back to 960×720.
Import VFX shot into FCP, and continue editing.My results have always been fine visually, but I’m trying to figure out a better workflow option. My hope in seeing the updated Comp Setting preset in CS4 would make this process a bit quicker and smoother, but the fact that the preset sets up a comp that is more or less unworkable visually is frustrating.
Anybody have any suggestions for a better workflow? (Other than simply exporting a ProRes422 or Animation encoded QT out of FCP).
Mac Pro 2×2.8 QuadCore; 6GB RAM; FCStudio2; Adobe Creative Suite 4 Production Premium
