Activity › Forums › Adobe After Effects › AE CS3 Render Fails
  • AE CS3 Render Fails
    Posted by James Orlowski on April 19, 2009 at 12:46 pm
    I’ve been having rendering issues with a project I’m working on.
    Here’s the error message that pops-up (at the same frame) eveytime I render:
    https://orlowskidesigns.com/temp/ae_crash.jpg
    The project is a SD 720×486 job, and no element in this job is larger than 864×486.
    But I am doing some 3D camera moves, with motion blurs and a light throwing a soft drop shadow onto an 720×486 background that I pushed way back on the Z-axis and blew up to fill the screen.
    If I turn off the motion blur and the light, it renders fine (but of course, doesn’t look as good as if I was able to keep them on).
    I have an HP workstation with 4 GB RAM running Windows Vista 32-bit. I realize in that environment, AE only uses 2 GB, so I did what the error message suggested, but it still fails at the same frame in the render.
    What am I supposed to do in this situation? Am I just not able to render this project? Will I have to “dumb it down” to make it render?
    We have one XP 64-bit workstation running the CS3 apps, so perhaps I’ll try rendering it on that machine. I has 8 GB RAM and AE sees 4 GB of it.
    Suggestions? Solutions?
    James Orlowski
    RYNO Production, Inc.
    http://www.rynoproduction.com
    800-860-7966
    James Orlowski replied 17 years, 5 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    April 20, 2009 at 11:57 am
    Try to start your render a couple of frames before the problem frame occurs. Sometimes AE fails to release memory. If this works then render out two passes and combine the movie either in AE or a non-linear.
    And if that fails –
    Render withouth the Lights and background and with an Alpha CHannel. IMport the movie and drop it into a comp and add your bakground. Apply Ramp (circular) to the background to fake a lighting effect and add Radial SHadow to the rendered movie.
    HTH
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • James Orlowski
    April 20, 2009 at 12:44 pm
    Thanks for the suggestions. I tried a few frames before, but it still fails.
    I turned off the light but kept the motion blur on, and it worked.
    I’ll just not use a light in this project. I can live without it.
    James Orlowski
    800-860-7966
  • James Orlowski
    April 20, 2009 at 7:40 pm
    UPDATE: This project renders fine on our 64-bit XP workstation. Guess the extra 2 gigs of RAM AE sees in that environment is helpful.
    James Orlowski
    800-860-7966
