Activity › Forums › Adobe After Effects › AE CS3 ignoring ram increase
  • AE CS3 ignoring ram increase
    Posted by Clif Willard on December 13, 2008 at 9:03 pm
    AE CS3 does not recognize an increase in available RAM. I increased my ram to 4GB. Then, RUN>C:\boot.ini> changed entry to read: /NoExecute=Optln /4GB. Restarted . I know that XP SP2 only recognizes 3.6GB of the 4GB installed. When I run AE CS3 it still shows 2.0 GB as max ram under preferences Memory & Cashe.
    What am I missing?
    Clif
    Jan Sherlink replied 17 years, 9 months ago 3 Members · 3 Replies
  • Jan Sherlink
    December 14, 2008 at 11:28 pm
    It’s the 3GB switch,
    not the 4GB 😉
    your boot.ini in wrong
    check this link: generalspecialist
    cya,
    Jan
  • Jon Geddes
    December 15, 2008 at 7:40 am
    Even with the 3GB switch, a single program is still limited to 2GB. Thats where the multiprocessing comes in hand, as AE will launch additional processes in the background which can also use up to 2GB of ram.
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
  • Jan Sherlink
    December 15, 2008 at 12:07 pm
    under XP32 can use 3GB Ram per instance using the 3GB switch !!
    XP32: AE uses 2GB/instance
    XP32/3GB switch: AE uses 3GB/instance
    XP64: AE uses 4GB/instance
    OSX: AE uses 3GB/instance
    cya,
    Jan
