Activity › Forums › Adobe After Effects › AE CS3 HD Footage Issues
Posted by Sbimedia on July 24, 2007 at 2:55 amI’ve been using AE 7 to key HD footage (DVCPRO HD 960×720 1.33) without issue. However, when I attempt to use the same footage with the same setting in AE 8 it looks pixelated. Any ideas?
Mike Procunier replied 19 years, 1 month ago 3 Members · 12 Replies -
Jeremy Garchow
July 24, 2007 at 4:36 amI don’t see this. Are you sure you have everything setup properly? Did you drag a piece of footage onto the new comp button to make a new comp that matches your clip’s settings?
Sbimedia
July 24, 2007 at 1:35 pmNo. I am opening an older AE7 session/composition in AE8. The footage looks and keys great in AE7. However, when I open the session in AE8 it becomes very pixelated.
Jeremy Garchow
July 24, 2007 at 2:52 pmAs a test, make a totally new project, import one of the DVCPRO HD files and try again.
it sounds to me like you PAR is messed up somewhere.
Jeremy
Sbimedia
July 24, 2007 at 3:33 pmNo. We’ve accounted for that. Take a look at this image:
https://www.sbimedia.com/demos/AE/AE7AE8Comparison.jpgIt shows the effect of “keyed”material in AE8 VS. AE7.
Same settings, same plug-ins, same footage, same frame.
Jeremy Garchow
July 24, 2007 at 3:46 pmAre you using keylight? There is an update to keylight for AE CS3. Try that.
It’s 1.2v6 specifically for AE CS3.
Also, have you tried ‘rekeying’ the footage in CS3 and see ing if your result is any better?
https://www.thefoundry.co.uk/pkg_downloads.aspx?ui=A5FB8E97-D752-4E01-AC7D-17B39B7E1192
Jeremy
Mike Procunier
July 24, 2007 at 4:04 pmAre you using the full release of CS3 or the CS3 Free Preview? The preview had some quicktime issues & issues with footage from AE7 projects.
Sbimedia
July 24, 2007 at 6:32 pmNo. Full version. CS3 Production Premium. Ordered it at NAB in April. We can’t figure this one out.
Jeremy Garchow
July 24, 2007 at 6:41 pmDid you update keylight?
DId you try with a brand new project, new import of footage and a new instance of keylight?(basically don’t restore anything from AE7, start fresh with CS3).
Jeremy
