Activity Forums Adobe After Effects AE CS3 Having problems with pre ram preview and renders
  • AE CS3 Having problems with pre ram preview and renders
    Posted by Josh Mackey on April 14, 2010 at 11:09 pm
    I’m hoping someone can help… I’m running CS3 and working on a project for the last 3 weeks… Everything has been fine except for a few glitches in the ram preview and render where background layers are not rendering correctly. They will play and then stop, jumping back and forth from 2 frames.
    I have checked all of my codec’s again today and re rendered my master QT files all at the same frame rate @ animation codec. But it contiues to happen.
    When I go back and check my master files they run fine in Quick Time.
    Suggestions?
    Jeffrey Kaplan replied 16 years, 4 months ago 2 Members · 1 Reply
