Activity › Forums › Adobe After Effects › AE CS3 Frozen footage
Posted by Tim Paul on August 24, 2007 at 5:43 pmWhen I chose a video clip in the project window and interpret footage to 59.94, then place into a 29.97 composition. I can scrub fine only up to 3 sec. 22 frames. Then it scrubbs no more. The remaining footage is frozen. The scrubber moves but will not show any more of the footage. It stays on the same frame at 3 sec. 22 frames.
My video footage uses the Animation codec millions+ with Alpha.
Any idea how to resolve the problem?
Tim Paul replied 19 years, 1 month ago 4 Members · 7 Replies -
Kevin Camp
August 24, 2007 at 6:01 pmdoes it play/scrub fine if you leave the interpret footage at the original frame rate?
the only thing i can think of right now, is that you are running out of ram. try choosing edit>purge>all.
if that doesn’t work tell us more about your footage…. size, frame rate…
Kevin Camp
Designer – KCPQ, KMYQ & KRCW -
Steve Roberts
August 24, 2007 at 6:05 pmYep, check the footage. This sounds unusual.
Here’s more shot-in-the-dark troubleshooting to isolate the cause if the footage is fine:
Slide the footage in the timeline to see if the stoppage happens at the same place in the action or the timeline.
Try dropping it into a 29.97 timeline.
Try RAM previewing around 3:22 and past.
Try dropping other footage into the timline and see if that freezes.
Try moving the footage to another drive.
Check your system monitors to see if you’re running out of RAM. -
Tim Paul
August 24, 2007 at 6:23 pmWow, you guys are fast.
I’ve verified the issue with Adobe , on hold right now in fact.
I did try all of the things each of you suggested. None corrected the issue.
The footage is fine and even plays in a QT window within AE (not in comp) just fine.
I’ve tried 5 diferent clips, using different codecs. All have the same issue.If the Adobe tech comes back with a valid answer, I will post it here.
Tim Paul
August 24, 2007 at 6:29 pmThe Adobe tech said it was an issue concerning Quicktime 7.2 and suggested I go back to 7.1.6.
I also tried swithching off multiproc in the preferences. Did not solve issue.
I am still hoping for a tip from you guys to solve this. Fingers crossed.
I am on a Dual Quadcore Xeon 3.0, 8gigs ram, os 10.4.10, AE 8.0.1.8
Thanks -
Tim Paul
August 24, 2007 at 7:31 pmNot yet. I did download 7.16, not installed yet. Still looking for instructions on how to downgrade from QT 7.2 to 7.16. I don’t expect it is easy.
Anyone have a link to instructions. Pain free prefered.
