Activity Forums Maxon Cinema 4D AE CS3 exchange plugin won’t load correctly
  • AE CS3 exchange plugin won’t load correctly
    Posted by Russ Maehl on July 17, 2007 at 12:38 am
    Downloaded the new CS3 exchange software.
    The folder included a file named “CINEMA4DAE.aex” as well as a zipped file named “C4DMac.zip”. I ignored the zipped file and installed CINEMA4DAE.aex assuming it to be universal. I installed it in AE 7 and AE8(CS3). Both apps report this error:
    After Effects error: opening resource file :”CINEMA4DAE.aex” – inexpected end-of-file (-39).
    Is this a problem only I am suffering, or is there some known issue with the new plug-in?
    Russ
    Russ Maehl replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
