Activity › Forums › Adobe After Effects › AE CS3 Crashing on renders
  • Jeremy Garchow
    July 26, 2007 at 8:15 pm
  • Kevin Monahan
    July 26, 2007 at 9:25 pm
    Yes, I did. This is tickin’ a lot of folks off. H E L P !!
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Kevin Monahan
    July 26, 2007 at 9:34 pm
    I finally got a look at the error message:
    After Effects Error: unable to allocate space for a 720 x 576 image buffer. You may be experiencing fragmentation. In the Memory and Cache Preferences dialog box, try decreasong the Maximum RAM cache option, increasing Maximum Memory usage or both.
    Kevin Monahan
    fcpworld.com
    Pres. SF Cutters
  • Darby Edelen
    July 26, 2007 at 9:35 pm
    [Kevin Monahan] “After Effects Error: unable to allocate space for a 720 x 576 image buffer. You may be experiencing fragmentation. In the Memory and Cache Preferences dialog box, try decreasong the Maximum RAM cache option, increasing Maximum Memory usage or both.”
    Did you try doing what it recommends? Also I’d recommend doing an occasional Edit > Purge > Purge All.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Raymond Tuquero
    July 27, 2007 at 4:37 am
    The memory thing helps a whole lot…don’t ask why. I had the same problem with Keylight on my AE and when I droped how much memory it was aloud it rendered fined. I keep my around 512-1GB…. very wierd. Hopefully an update will occur to fix this issue.
    -Raymond Tuquero-
    Houston Editor-
  • Tim Vaughan
    July 27, 2007 at 3:34 pm
    Actually, it is a pain why it was set up this way, but an easy fix. I have found that going in to your preferences–>Memory and Cache and set them to the following:
    Max Memory Usage: Leave at what it is (mine is at 120%, or equal to 3GB
    Image Cache: 33% –This is where the problem most likely occurs, so the lower, the better
    Check the Enable Disk Cache, and specify the settings where you would like it to save to
    From what I have learned, you do NOT want it to render image cache to your memory. There is not really any need for it. Have it render to the disk. It works so much better
    Hope this helps
    Tim
    Tim
  • Darby Edelen
    July 27, 2007 at 6:03 pm
    [Tim Vaughan] “From what I have learned, you do NOT want it to render image cache to your memory. There is not really any need for it. Have it render to the disk. It works so much better”
    Disks are slow, RAM is fast. It’s really a balancing act. If you set your Image Cache too high then AE will be pushing the limit on RAM usage and you’ll probably run into instability, if you set it too low then AE is slower to access cached data.
    In my case the default setting of 60% has always worked fine.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Theo Brown
    June 23, 2008 at 4:37 pm
    btw, this also solves the problem for Keylight using AE CS3 on a dual processor. Thanks for the fix, Tim. This was driving me crazy.
    Craig
