Activity Forums Adobe After Effects AE CS3 crashing a lot…
  • AE CS3 crashing a lot…
    Posted by Lon Waitman on February 10, 2009 at 9:16 am
    I am running into a lot of issues with a AE CS3 on a new system (Dell Precision T7400, Dual Quad 2.5 GHz, 2 GB of RAM, Nvidia Quadro FX 570). AE is part of Production Premium. One of the issues is a crash that happens part way through renders. Most recently I got this series of messages:
    -The application has requested the Runtime to terminate in an unusual way.
    -Runtime error, R6025 – pure virtual function call
    -unknown software exception 0x40000015 occurred in the application at location 0x067838da
    I have received this sort of error messages more than once while rendering comps for this project.
    I am working on a project that has a lot of chroma keying (using Keylight) and a lot of use of a plugin called ToonIt!
    I also run into a lot of crashes as I am scrubbing along the timeline (which I am having to do a lot for this project).
    AE CS3 was a little temperamental on my old system (Dell Precision 650, dual 3 GHz Xeons, 4 GB of RAM), but nothing like this. :o(
    Any ideas?
    (I know 2 GB is very little RAM. I have two more GB on the way.)
    Tarik Kiddoe replied 17 years, 2 months ago 3 Members · 4 Replies
  • Lon Waitman
    February 10, 2009 at 7:55 pm
    Is there anyone out there who is using AE as part of the CS3 Production Premium package (on a dual quad PC) that is finding success?
  • Lon Waitman
    February 11, 2009 at 5:03 am
    PPSS: New rendering error (well, variety is nice…) Instead of runtime errors or “AE has to close” or having AE just disappear, now, when I try rendering a comp from this project, I got: “After Effects AEGP Plugin Tiffio: Error reading TIFF data (5027::12)”
    But I wasn’t rendering TIFFs. The project contains a number of PNG sequences, and I am trying to render out as another PNG sequence. :o\
  • Shane Mecklenburger
    April 23, 2009 at 7:43 pm
    I’m experiencing the exact same problem.
    Anyone find a solution?
    Shane
  • Tarik Kiddoe
    July 6, 2009 at 5:34 am
    Had a similar problem. The problem is caused by the fact that the image sequence changed attributes in the middle of the sequence. I rendered about 1000 frames of 3D as tiff, then in a subsequent render, re-rendered only 600 tiff frames, but the second time around i saved the newer images in a compressed format. AFX had dificulty transitioning between the compressed and uncompressed images in the sequence.
    My Solution: re-render the remaining 400 frames in the same format as the first 600.
