Activity Forums Adobe After Effects AE CS 5 Cant open/export QuickTime (Win 7 – 64bit)
  • AE CS 5 Cant open/export QuickTime (Win 7 – 64bit)
    Posted by Andrea Rusky on May 27, 2010 at 4:28 am
    on the same machine, i have CS 4 and no problem opening and exporting in quicktime
    but with CS 5 i can’t
    i uninstalled and re-installed quicktime..but nothing changed
    here my specs:
    Quicktime Version 7.7.6
    Windows 7 Ultimate 64 bit
    Adobe After Effects CS 5
    thanks
    a.
    Ken Geary replied 14 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Todd Kopriva
    May 27, 2010 at 1:44 pm
    Exactly what are you doing, and exactly what does After Effects do and tell you?
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Andrea Rusky
    May 29, 2010 at 9:17 am
    i dont see quicktime as option when i select the output file format in the render queue
    and i can’t import quicktime movies (H264 or PNG codec..but i think any of the codec won’t work)
    the error i’ve got when i try to import quicktime is this:
    After Effects error: file ‘filename.mov’ cannot be imported – this
    ‘.mov’ fle is damaged or unsupported.
    thanks
  • Andrea Rusky
    June 1, 2010 at 4:30 am
    ..and i forgot to mention, it when i start after effects, it takes very long time
    it’s like stuck with “Initializing MediaCore” so i guess there is something wrong with
    the Quicktime / MediaCore
    There is a way to reset the preferences… ?
    thanks
    a.
  • Todd Kopriva
    June 2, 2010 at 1:01 am
    We’re in the midst of tracking this issue and some related issues down. There are a few potential solutions here.
  • Todd Morgan
    August 10, 2010 at 8:43 pm
    Hi Todd,
    Has Adobe come up with a proper solution to this issue? I can’t start CS5 in my user account, but when I create a new user I have no problem starting CS5.
  • Todd Kopriva
    August 11, 2010 at 3:13 pm
    Here is a document that addresses one problem regarding crashes or hangs on start, as well as some problems with QuickTime:
    https://kb2.adobe.com/cps/857/cpsid_85711.html
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Metta Xu
    December 21, 2011 at 10:49 am
    I’ve got the same problem with CS 5.5 AE. I tried to import some .mov files to work on but it gives me an instant error “After Effects error: Cant’ import file “abc.mov”: unsupported filetype or extension (0::1)
    I have CS 5.5 production suite, using AE.
    – AMD 1100 6 cores
    – GTX 560 ti
    – 16 gb ram
    – Windows 7
    – Quicktime 7.7.1
    I’m new to AE but I believe .mov are pretty standard file formats so I don’t understand why I cannot import .mov files to AE. Can some kind soul share some advise? Many thanks.
  • Ken Geary
    February 1, 2012 at 4:59 pm
    Same issue here and with a brand new fresh insatll of Win 7 Pro and CS 5.0 with all updates.
    Seems AE cant handle .mov as source and export to another .mov
    The UGLY workround is to export first to lossless AVI (dont forget to check audio output if needed). THEN import that AVI drop on new timeline and export to QT , also helps to select Edit > Purge> All to clear out any memory cache from RAM previews.
    Hope that helps
    Ken
