Activity › Forums › Adobe After Effects › AE crashes at startup
  • AE crashes at startup
    Posted by Andrés Mendez on January 6, 2009 at 2:43 am
    Hi people, im having trouble at startup, im using AE CS3 and when crashes it throws me “failed to initialize mediacore”.
    Then the program runs but it kinda throw some artifacts in the project im working, like little black bars ruining everything, those also appear on the exported render.
    I tried updating codecs and downloading the latest quicktime but nothing works.
    CS3 is the only alternative because my partners are sending me AE CS3 projects.
    Google doesnt help to much, only a few results came up.
    Well thats it, anyone have any idea? dont be shy, everything help.
    thanks
    Andrés Mendez replied 17 years, 8 months ago 4 Members · 6 Replies
  • Chris Wright
    January 6, 2009 at 6:52 am
    this has worked for some…
    uninstall and remove pref folder in AE folder. re-install and turn off open gl.
  • Jan Sherlink
    January 6, 2009 at 7:49 am
    indeed, not that much to find on google…
    Quicktime and Codecs are key here, but you’ve done that already.
    Do you have a 3rd party Video-card ?
    Installed updates recently ?
    Resetting AE won’t probably help here, but you can try (boot AE while holding CTRL+SHIFT+ALT)
    It seems most people find the solution in a new OS installation 🙁
    cya,
    Jan
  • Andrés Mendez
    January 6, 2009 at 12:55 pm
    Im working on windows xp proffesional sp3. So you sugest that i should reinstall windows?
    Mi video card is an integrated onboard Mobile Intel 965 Express Chipset Family. Not shure about the qualities of the card itself.
    I have a Intel Core2 Duo CPU T5750 @ 2GHz, and 3 GB of RAM.
    I´ve tryed everything, even uninstalling and cleaning the registry, even i´ve done a useful disk defregmentation. and then installed AE with my computer absolute clean.
    Other failures that this generates is the fact that i cannot import video files and its getting unable to activate openGL.
    So, im out of ideas. Also i´ve boot the program holding SHIFT+ALT+CTRL. Nothing with that.
    Chris: what is the pref folder?
    Thank you all for the help you are giving to me.
  • Roland R. kahlenberg
    January 6, 2009 at 5:20 pm
    Switch off OpenGL from the OS. Ensure that AE is not running while you’re doing this. After switching off OpenGL, retart your computer and check that OPenGL is still switched off. Then say a prayer and run AE.
    Good Luck!
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Jan Sherlink
    January 6, 2009 at 5:46 pm
    you can switch off the Hardware Acceleration in
    control Panel -> display properties -> settings -> troubleshoot
    if it helps, the error has something to do with the display-drivers,
    rolling back to an older driver might help.
    maybe you can restore your system to a date it still worked,
    if you’ve made restore points ?
    other than that,
    to have hardware accelleration back again nobody seemed to have a better solution than reinstallings your OS 🙁
    Sometimes it’s just the fastest way !
    cya,
    Jan
  • Andrés Mendez
    January 7, 2009 at 2:23 pm
    Nothing worked people…
    I´ve downloaded a portable version of the program and it throw me the same error but at least its leaving me work without those ugly bars on my preview. Im still not importing any video files and openGL still unable to check. But i can work now.
    I´ve been working just perfect on After Effects 7.0, and it still installed and working perfect. I dont get it…
