Activity Forums Adobe After Effects AE crashes and Premiere low level exception error
  • AE crashes and Premiere low level exception error
    Posted by Bart Stevens on September 18, 2018 at 5:03 pm
    I’m having issues with both After Effects and Premiere.
    In Premiere, my project works fine for a while (maybe 15 – 20 min). Then I get a “low level exception error”.
    I can save the project, but my cineform files are not readable. When I reopen the project, files are fine (for a while) then same thing happens.
    If I import the Project into After Effects, I get the same problem, but cannot save.
    I’m working with both new and older cineform files. I’m not a hundred percent certain, but think the problem is mostly with older cineform avi files, maybe a conflict with the codec?
    Shouldn’t both Premiere and After Effects be able to read cineform files natively?
    At some point I wasn’t able to play older cineform avi files, so installed a older version of the codec. Then I could read the files, but now I’m getting these crashes.
    I’ve tried reinstalling several times and rolling back to earlier programs, turning off CUDA in project settings, clearing cache… etc…
    Anyone have a similar problem?
    Here’s the crash data:
    Premiere:
    A low-level exception occured in: Importer AVI (Importer:47)
    Adobe Premiere Pro.exe
    12.1.2.69
    5b34ba17
    ntdll.dll
    6.1.7601.24214
    5b6273e1
    c0000374
    00000000000bf6b2
    4d6c
    01d44a0c29cbaca7
    C:\Program Files\Adobe\Adobe Premiere Pro CC 2018\Adobe Premiere Pro.exe
    C:\Windows\SYSTEM32\ntdll.dll
    52c6d24b-b600-11e8-8aad-989096ae209b
    After Effects:
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: AfterFX.exe
    Application Version: 15.1.2.69
    Application Timestamp: 5b35ca62
    Fault Module Name: StackHash_9782
    Fault Module Version: 6.1.7601.24231
    Fault Module Timestamp: 5b6db5a7
    Exception Code: c0000374
    Exception Offset: 00000000000bf302
    OS Version: 6.1.7601.2.1.0.256.48
    Locale ID: 1033
    Additional Information 1: 9782
    Additional Information 2: 9782935300ff3de25ffed55ec0e933fb
    Additional Information 3: d85f
    Additional Information 4: d85fe3117521d458fce67542c0bd2813
    Read our privacy statement online:
    https://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    Event viewer:
    Details:
    AfterFX.exe
    15.1.2.69
    5b35ca62
    ntdll.dll
    6.1.7601.24231
    5b6db5a7
    c0000374
    00000000000bf302
    152c
    01d44ef6cb135f59
    C:\Program Files\Adobe\Adobe After Effects CC 2018\Support Files\AfterFX.exe
    8febfd58-baea-11e8-b5b7-989096ae209b
    General:
    Faulting application name: AfterFX.exe, version: 15.1.2.69, time stamp: 0x5b35ca62
    Faulting module name: ntdll.dll, version: 6.1.7601.24231, time stamp: 0x5b6db5a7
    Exception code: 0xc0000374
    Fault offset: 0x00000000000bf302
    Faulting process id: 0x152c
    Faulting application start time: 0x01d44ef6cb135f59
    Faulting application path: C:\Program Files\Adobe\Adobe After Effects CC 2018\Support Files\AfterFX.exe
    Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
    Report Id: 8febfd58-baea-11e8-b5b7-989096ae209b
    Bart Stevens replied 7 years, 11 months ago 1 Member · 1 Reply
  • Bart Stevens
    September 18, 2018 at 6:14 pm
    Thanks for the feedback Dave…
    No, not using dynamic link. I usually just : File > import > Premiere Pro project.
    Again, having trouble with both programs independently.
    Very strange, because both work okay for a while, then crash…
    I’m reluctant, but might try re-rendering older cinefrom avi files into cineform mov. Re-cutting my reel, so not an easy task.
    Thanks again,
