Activity Forums Adobe After Effects AE Crashed whilst “invoking plug-in”
  • AE Crashed whilst “invoking plug-in”
    Posted by Adam Taylor on December 2, 2008 at 4:26 pm
    I’m kinda stuck….
    AE CS4 just crashed giving an error message about “whilst invoking plug-in Auto Levels”. It then tells me it has saved a copy of the project.
    However, it has saved the project with the plug-in that is causing it to crash, so everytime i try open the project it immediately crashes. Any idea how i can open the project with out the offending plug???
    I’m on Mac 10.5.5 with AECS4.
    thanks
    Adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    Todd Kopriva replied 12 years, 9 months ago 4 Members · 5 Replies
  • Adam Taylor
    December 2, 2008 at 4:54 pm
    its a color correction plug-in, and i caught it by accident when trying to select the levels tool !
    Adam Taylor
    Oldham, UK
  • Kevin Camp
    December 2, 2008 at 6:05 pm
    to open the project with the bad effect, just turn the caps lock key on prior to opening the bad project. this will disable the preview update when the project opens, which will effectively disable the rendering of the effect, allowing you to go in and remove the effect form the comp.
    once the effect is removed you can hit the caps lock key again and work as normal, perhaps saving first 😉
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Adam Taylor
    December 3, 2008 at 10:42 am
    brilliant – thanks kevin. Just what i needed.
    adam
    Adam Taylor
    Oldham, UK
  • Juan Vela
    March 4, 2013 at 6:49 pm
    Interesting, I am having the same problem with other color plugins, I have the same error once in a while with Color Finesse 3 and Colorista II in AE6. But I can reopen the project and keep on working on it until the next random crash happens.
  • Todd Kopriva
    December 14, 2013 at 8:06 pm
    The After Effects CC (12.2) update fixes a cause of a crash involving the Auto Contrast effect, Auto Levels effect, and related effects.
    Let us know how it works for you after you’ve installed the update.
    After Effects team blog
