Activity Forums Adobe After Effects AE Countdown
  • AE Countdown
    Posted by Dan Cooper on September 23, 2006 at 1:00 am
    I’m wanting to create a count down in AE (min:sec), but can’t set it to start at 60sec. Instead it starts countdown from ’99’.
    I have used the ‘Text > Numbers’ effect, but perhaps i am on the wrong track.
    If there is a champion among you that knows how to defeat this challenge, and can spare a couple secs i would love your counsel.
    Dan
    Julian Sixx replied 19 years, 11 months ago 4 Members · 3 Replies
  • Jason Brown
    September 23, 2006 at 4:53 am
    I’ve had success using the effect: Effect > Text > Timecode
    This will count with the comp’s timecode…then, just change your stretch on the layer to -100% and you are in luck.
    However, this makes a format of 00:01:00:00 instead of 60:00…so you can precomp it and mask the first several 0’s … or I’m sure there’s a way to use the text animator to keyframe using character value or something.
    Good luck!
    -Jason
  • Mike Clasby
    September 23, 2006 at 5:48 am
    This gives you a 60 to 0 countdown.
    In the Effect>Text>Numbers
    Type: Numbers
    Decimal Places: 0
    then keyframe the Value/Offset/Random Max to 60, and another keyframe down the line to 0, and the countdown runs from 60 to 0 between keyframes.
    Or
    Maybe this earlier post will work, 60 is 1:00 then to 0:59, 0:58 etc. You need to set a simple rectangular mask to show only the 1:00, and add a slider (Effect>Expression DControls>Slider Control) so you can keyframe the countdown. Sam’s expression goes on the Source Text Stopwatch (Alt Click the stopwatch and Paste the expression), after you typed anything with the Text Tool. I like this one.
    Date: May 22, 2006 at 1:18:53 pm
    Subject: Re: Countdown Timer in AE
    you can also use this expression with a slider to make a hrs:min:sec:1/100 timer bu masking out the top dot in the last column
    timeToTimecode(t = effect(“Slider Control”)(“Slider”), timecodeBase = 100)
    just took the basic expression from the global properties and changed the timecode base and added a slider to change the number.
  • Julian Sixx
    September 23, 2006 at 6:05 am
    Hi
    you can have it much easier.
    In the effect >text>numbers just use Time for TYP and you’re done.
