AE Composition Preset: File Size/Dimension
I am very new to AE. When making a new composition, i don’t understand/know what “Preset” (i.e. NTSC DV, HDTV 1080 29.97 & all the other presets etc) I should use when starting.
I am from the print world of design and have regular paper dimensions that we use the most – A5, A4, A3 etc; Is there a standard rule you go by or regular settings most people use in After Effects that’s similar to print?
Thanks for any help and advice that can be given.
