Activity Forums Boris FX Sapphire AE Compatible vs. FxPlug Plugins?
  • AE Compatible vs. FxPlug Plugins?
    Posted by Michael Thibault on February 23, 2009 at 10:51 pm
    I’m considering buying the Sapphire plugins suite, but my work is spread out between the FCP timeline, After Effects CS3 and Motion 3. Do I get more cross platform compatibility with the After Effects compatible plugin, or do I lean on the FxPlug architecture for stability?
    Any and all opinions would be greatly appreciated. Thanks!
    BTW, I’m on a MacBook Pro, 2.4 Ghz Intel Core Duo w/4GB RAM, working in FCP 6, Motion 3 and AE CS3.
    Michael Thibault replied 17 years, 7 months ago 2 Members · 2 Replies
  • Gary Oberbrunner
    February 24, 2009 at 1:36 pm
    Hi Michael. I’d recommend using the FxPlug ones in FCP and Motion, and the AE ones in AE. Your Sapphire license will work with both software versions as long as they’re used on the same machine. Just download and install both of them, then install your serial number, and they’ll both work fine.
    — Gary
  • Michael Thibault
    February 25, 2009 at 10:32 pm
    I did and it worked great. Thank you.
