Activity Forums Adobe Premiere Pro AE comp with vector file is jagged in PPCC export
  • AE comp with vector file is jagged in PPCC export
    Posted by David Seay on September 21, 2016 at 4:11 pm
    I’ve been having trouble getting clean graphic exports from PPCC when importing AE comps with vector files. They were a little jagged around the curved edges. Yes they were rasterized and perfectly fine inside AE but not in PPCC export. I solved the issue (sort of) so hopefully someone else can benefit from this:
    workflow:
    AFTER EFFECTS – create comp with vector logo; export via animation codec; frame rate/pixel aspect/comp size all double checked and correctly matched to PPCC comp
    PREMIERE PRO CC – import AE comp; drop into timeline; ADD BLACK LAYER ON TOP AT 3% OPACITY; edges magically sharpen up; adjust picture to compensate for black layer
    It’s weird I know, but this trick works (see the attached photos) Anybody else deal with this issue in a different way?
    https://www.davidseayproductions.com/pub/without_black_layer.png
    https://www.davidseayproductions.com/pub/with_black_layer.png
    TV- It’s why Kennedy beat Nixon
    david seay
    David Seay replied 9 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
