Activity Forums AJA Video Systems AE comp setting for SD 16×9
  • AE comp setting for SD 16×9
    Posted by Craig Meadows on November 18, 2005 at 3:10 am
    Using Kona 2 to edit SD 8-bit ntsc anamorphic/16×9 shot on a SDX-900.
    What are the proper After Effects comp settings?…everything I try seems stretched or squashed in AE.
    Craig Meadows replied 20 years, 10 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    November 18, 2005 at 4:42 am
    You should set your comps to 853×480 (which is a 16:9 ratio) and then squish (check the ‘stretch’ box) the file down in the output module for final render down to 720×480. These settings are if you are digitizing @ 720×480.
    If you are using the uncompressed 8 bit codec the numbers are: create @ 864×486, then squeeze down to 720×486 in the output module for final render.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
  • Craig Meadows
    November 18, 2005 at 12:00 pm
    Thanks Jeremy!
