Activity Forums Adobe After Effects AE comp blurry when I import it into avid
  • AE comp blurry when I import it into avid
    Posted by John Castelli on May 6, 2008 at 1:16 am
    Hello,
    has anyone ever had an issue where you render out a composition that seems to look fine in a quicktime, but then when you import it into avid it looks extremely blurry?
    My AE project was 720×480 and I exported it with a number of different settings and it never worked. I tried with the avid DV codec, the animation/ lossless/ and avid meridian and none of them worked. My other settings were mostly set to use the comp settings, and I have tried using field rendering. Also, I have tried just about every import combination in Avid just to be safe- nothing worked.
    I’m working on Media Composer 2.8- If anyone knows how to fix this problem I would really appreciate the help!
    John
    Gene Gemperline replied 18 years, 4 months ago 2 Members · 1 Reply
