Activity Forums Adobe After Effects AE Color Correction
  • AE Color Correction
    Posted by Fred Beahm on April 18, 2008 at 4:45 am
    Is there a color corrector that is similar to FCP’s 3-way color corrector for AE ?
    I have brought my FCP sequence to AE with automaticduck and lost all my color correction.
    Now I have to redo it.
    I want to be able to have the same kind of color correction workflow though.
    I have tried colorista, but just don’t like it that much.
    Any suggestions/help would be greatly appreciated!
    Fred
    Fred Beahm replied 18 years, 5 months ago 3 Members · 3 Replies
  • Brian Berneker
    April 18, 2008 at 7:03 am
    Colorista is probably the most similar to FCPs 3-way color corrector.
    https://www.redgiantsoftware.com/coloristafeatures.html
    Other than that, there are plenty of photoshop similar filters in the effects > color correction menu to play with!
    Brian
  • Brendan Coots
    April 19, 2008 at 6:02 pm
    Personally, I just use a combination of Levels, Hue/Saturation and Exposure. Used properly, this combination can do anything you might ever need to do, and offer far greater control than the color wheels of FCP. This technique is used on feature films, commercials etc. so rest assured these tools offer a professional level of quality and control. You just need to know how to use them properly.
    That said, After Effects 6.5 and up comes bundled with a third-party program called Color Finesse, which offers all the color correction tools you’d find in FCP and more. When you apply it as an effect to a clip, it launches the app in a separate window which can take some getting used to, but it works great. Here’s Adobe’s description:
    Color Finesse™ from Synthetic Aperture, a professional color processing system that uses a 32-bit floating-point color space for precise adjustments. With Color Finesse you can fine-tune color corrections in HSL, RGB, CMYK, and Y’CbCr color spaces and take advantage of automatic color matching and custom correction curves. You can monitor all color levels using the built-in waveform monitor, vectorscope, histogram, and correction-curve displays in Color Finesse.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Fred Beahm
    April 19, 2008 at 6:43 pm
    Thank you both for your comments.
    I am going to play with both methods to see which I should choose. I basically want to have easy control over my whites like in FCP. I am sure both will do fine with that. There might be a learning curve, like you said, but that is fine with me. Just wanted to see what everyone else is using in AE if they had to.
    Thanks again for your comments, very appreciated.
    FrEdtior
