Activity › Forums › Adobe After Effects › AE clips highlights from clips exported from FCP!
  • AE clips highlights from clips exported from FCP!
    Posted by Mark Linthicum on July 4, 2008 at 6:40 am
    Message:
    I have had this problem before and am geting a bit fed up,
    I have a ProRes HD movie in Final Cut Pro, i export it to a QuickTime bring it into AE and the highlights are clipped.
    Here is the clip split screen, Movie , it should be obvious but the AE is on the right.
    Anyone know what this is about??
    Thanks, Mark
    Chris Wright replied 18 years, 2 months ago 4 Members · 4 Replies
  • Joey Foreman
    July 4, 2008 at 2:44 pm
    How do the highlights look in the Quicktime player, or reimported into FCP?
    Have you switched AE to 16 or 32 b.p.c?
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Mark Linthicum
    July 4, 2008 at 6:51 pm
    Joey,
    AE is in 16 bit mode.
    If I import the the clip back into FCP without going to AE it looks fine. it is only when going to AE I have a problem. i have to bring down the highlights in FCP then export to AE to make sure nothing changes.
    Thanks, Mark
  • Scott Roberts
    July 4, 2008 at 8:05 pm
    Try using a different codec than ProRes. Try Animation, or PNG or PhotoJPG. Something that is cross-platform.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
  • Chris Wright
    July 5, 2008 at 9:58 pm
    You probably don’t have the amazing color management on. It’s just like if you import a SD NTSC from premiere into AF, it’s all dark until you change to file->project settings, SD color management. Same thing with Quicktime. Quicktime’s player is a lil wonky cuz its gamma is set really high, that is why AE is clipping, AE doesn’t interpret the gamma curve the same way. You have to tell it how to preset gamma.
