Activity › Forums › Zaxwerks › AE CD5 3D flag 2 size distortion bug
  • AE CD5 3D flag 2 size distortion bug
    Posted by Kit Carson on September 17, 2011 at 7:00 am
    I am running 3D flag in AE CS5 and experiencing a strange issue where the size of the source file (flag image) seems to stretch when the 3D flag plugin is applied. When I scrub back and forth in the timeline the un-rendered frames will display the effected flag in the correct proportions, however when it displays the rendered frames the flag size is horizontally stretched. Using 3D Flag 1.5 in CS4 does not present these problems.
    Could you please look into this asap.
    Thank you.
    Edward Wu replied 15 years ago 2 Members · 4 Replies
  • Kit Carson
    September 18, 2011 at 1:09 pm
    If I also click on the 3D flag effected image file in the comp viewer it changes size every time I click on it to the proper size, then when I unclick it goes back to the distorted stretched size.
    If this is any help, I just created a composition in After Effects CS4 and added 3D flag 1.5 to a layer. If I open up that CS4 project file in CS5 it automatically replaced the 3D flag 1.5 with 3D flag 2.0 hoever there are no sizing bugs and everything works fine. Strange??
    I will be using this method to continue on this project as the deadline is very soon.
  • Edward Wu
    September 19, 2011 at 7:17 pm
    Hi Kit,
    If you have a project file where this is happening, please send the project file to me so I can take a look at what’s happening. Also, please let me know whether you are working on Windows or Mac, and what OS (Operating System) you are working on.
    Thanks.
    Best,
    Edward
  • Kit Carson
    September 20, 2011 at 2:07 am
    Hi Edward I have sent the file via the zaxwerks support email address.
    Thanks.
  • Edward Wu
    September 20, 2011 at 5:52 pm
    Thanks. I took a look and your project and responded to you through e-mail. Please take a look at your e-mail.
    Best,
    Edward
