Activity › Forums › Adobe After Effects › AE CC2018 converts AE cc2014 projects
Posted by Umberto Giannini on February 15, 2019 at 9:45 amGood Morning,
In short the majority of our after effects projects are created in CC2014 which i know is old and i do need to migrate to CC2018. when i open a project in CC2018 it has to convert it to open it.
Could someone explain why please?Umberto
Lead Post Production Systems Engineer
Michael Szalapski replied 7 years, 7 months ago 3 Members · 4 Replies -
Tero Ahlfors
February 15, 2019 at 10:30 amBecause you’re opening an older project with a newer version. There’s probably some under the hood and compatibility stuff going on.
Tero Ahlfors
February 15, 2019 at 6:56 pm[Dave LaRonde] “I have a more cynical explanation: Adobe wants to keep people using the most current versions of its software, no matter what the users actually want to do. “
If this would be the case then why are there options to save to an earlier version?
Tero Ahlfors
February 17, 2019 at 8:16 am -
Michael Szalapski
February 19, 2019 at 8:16 pmWhile you are correct that Dave is wrong (it saves back two versions and not just one – as demonstrated in your screenshot), that isn’t “CC 2014”; that’s AE version number 14 which is commonly called “CC 2017”. CC 2014 was version 13.0-13.2.
To answer the original question, the reason AE needs to save new project file formats is that lots of things change in big and small ways between versions. The amount of QA overhead it would take to try to eliminate issues between versions is not-unsubstantial. The more versions back they have to go, the more work it takes away from them adding new things to AE.
I’m not excusing Adobe, by the way, I’m just explaining the reason for the issue. The AE team is very small compared to what people think it is. Photoshop (which has an exponentially larger team) does have the ability to bounce between versions without issue. But they also have ten times as many people on the team. (I don’t know that it’s 10 times, it could be 50 for all I know – I just know it’s HUGE in comparison.)
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
