AE CC16.1.3 clipping high numeric values from an imported .csv file at 32,768
Hey users,
I need to import data into AE CC 2019 from a Google sheet. I export the sheet as a .csv file which is the used to drive my animated contents. For some reason any higher numeric value in the .csv file is imported into AE clipped at 32,768. I understand that this value represents a pixel position limit, or the maximum RGB values in 16 bit mode. However there is no reason why a list of simple numbers, ranging from 0 to say 200,000, should be clipped at that value. I’m at a loss as to why that should be, yet obviously AE seems to be misinterpreting these values somehow. ANy suggestions what may the reason for this be, and even more importantly, how to resolve this issue?
Thank you
peter
