Activity › Forums › Adobe After Effects › AE CC: replace moving BW image with footage
  • AE CC: replace moving BW image with footage
    Posted by Max Van meer on May 6, 2014 at 10:54 pm
    Hello,
    I have a moving, animated black and white alpha layer of a small plane (the plane is white, the background is black), and I’d like to replace it with footage (an image) so that the footage is moving like the white plane did.
    What’s the fastest way to do this?
    Thanks a lot!
    max
    Max Van meer replied 12 years, 4 months ago 2 Members · 2 Replies
  • John Cuevas
    May 7, 2014 at 2:18 am
    Create a new comp and drag both the alpha matte and the footage into the comp. Place the alpha layer on the top of the layer stack. Change the footage layer’s track matte(if the track mattes pulldown isn’t visible, press F4) to alpha matte and it will show in the white area’s of the alpha layer.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Max Van meer
    May 7, 2014 at 8:40 am
    Thank you, that helped!
