Activity Forums Adobe After Effects AE CC 2017 full of bugs
  • Tim Kurkoski
    March 29, 2017 at 6:48 pm
    > I’m having a similar issue with one particular project where I’m not able to use my preview function, so I’m basically having to animate by force scrubbing.
    > Oddly, I can’t use the “redo” function either. It remains greyed out.
    > When I start a new project preview and “redo” work fine. When I import the project I’m having issues with preview and “redo” both stop working. Deleted the project file from the new project and both features started working again.
    Nick, would you be willing to share your project with me so I could take a look at it?
    Feel free to email me the link if you don’t want to share it publicly. myLastName at myCompanyName dot com.
  • Nick Vongremp
    March 29, 2017 at 8:54 pm
    Thanks for the response Tim. Not sure how I’d go about sharing the project with you since there are a several hundred GB’s of files cut together at this point. Any ideas?
  • Tim Kurkoski
    March 29, 2017 at 8:58 pm
    Nick, I may or may not need to inspect the footage. Just the .aep may be sufficient.
    Does every comp in the project have the problem, or only certain comps? If you reduce the project to the problematic comps, does that shrink the file size?
    Dropbox, FTP, or whatever file transfer service you prefer is fine. I can arrange for an FTP on my side, but please email me first and we’ll work out the details privately.
  • Tom Smith
    March 30, 2017 at 9:39 am
    As I’m the one who started this thread, I wanted to add my 2 cents: I’ve waited til the beginning of March to reinstall AE 2017, and now everything works like a charm. Though I wanted to ask a question to everyone using CC 2017: does the interface seems snappier to you comparing to other versions? Rendering time seems to be the same but building the project, adding effects and generally working on the project seems a bit faster, I wonder if Adobe teams are working on this specifically before re-engineering the rendering process.
  • Tom Smith
    March 30, 2017 at 10:13 am
    PS: that would be cool if some of you could do this test https://vimeo.com/118053656 to see if clock speed beats multi processing once again in the new AE 2017.
    Here’s my result:
    Setup: Mac Pro 5.1 32GB RAM, XEON 2X6 core at 2,66GHZ, Nvidia GTX 960 4GB
    AE CC 2014 with MP ON: 5:38sec
    AE CC 2017: 7:7sec
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Tommy Dimmel
    April 4, 2017 at 8:38 pm
    Michael Litty posted “With this new update, however, the playback never smooths out. Even after a few attempts. Letting it play through once or twice doesn’t help.” Exactly my problem.
Page 6 of 6
