Activity Forums Adobe After Effects AE Can’t See Textures
  • AE Can’t See Textures
    Posted by Justin Hawley on December 2, 2005 at 8:41 pm
    Hello!
    Having a funky problem. I have a project in which I have a nested composition with a texture applied to a solid layer (which also is gridded into bars) in that nested composition.
    When I added the texture through the “texturizer” plugin to the original composition, it seemed to work great. But when I went to the composition using it within nested, I couldn’t see any texture. Any thoughts?
    Thanks, guys.
    Justin.
    Justin Hawley replied 20 years, 8 months ago 3 Members · 5 Replies
  • Justin Hawley
    December 2, 2005 at 8:49 pm
    Ok, it’s got something to do with the camera. When I move the camera, the textures disappear, but when the camera stops, they are there. HELP!!!!!!
    Thank you!
    Justin.
  • Michael Szalapski
    December 2, 2005 at 9:18 pm
    Turn off the Open GL?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Justin Hawley
    December 2, 2005 at 9:24 pm
    I turned it off in the composition window, but it still looked the same. Thanks for the post! I hope to figure this one out! 🙂
    Justin.
  • Yussef Cole
    December 4, 2005 at 4:10 am
    Why not apply the effects to the nested comp in the master comp instead of within the nested comp? This may be able to get you around what sounds to me like a collapse transformations issue.
    Yussef
  • Justin Hawley
    December 28, 2005 at 12:56 am
    The solution was so obvious I should have known better. The texture layer was imported at a later point in time than the beginning. The texture has to actually be under the layer at any given point in time in order to be used.
