Activity › Forums › Maxon Cinema 4D › AE cams
AE cams
Posted by Nicholas Toth on June 2, 2005 at 3:02 pmAnyone know how to export just the ae camera?
Without rendering the entire scene again?Cheers
nicktothJoe Bird replied 21 years, 3 months ago 3 Members · 2 Replies -
Chris Smith
June 3, 2005 at 3:56 pmWell I was waiting for a response myself. But have you tried just turning off all objects, lights, and post effects? I would think with nothing to render you could blaze through it pretty quick.
Chris Smith
https://www.sugarfilmproduction.com -
Joe Bird
June 7, 2005 at 4:23 amIf you mean export the c4d cam for AE… In render settings/save, check compositing file, set to ae project. No need to re-render. hit save. import .aec into AE, viola! a c4d cam in ae (inside a comp.)
Potential gotchas,… make certain your original render settings are intact, like frame count, also make certain camera is active in render viewport…
HTH
