Activity Forums Adobe After Effects AE Camera Tracker: red bullseye disappears
  • AE Camera Tracker: red bullseye disappears
    Posted by David Markey on October 23, 2014 at 11:34 pm
    After applying Camera Tracker to a scene, I selected 3 track points to get the red bullseye. Then I right-clicked and selected ‘add text and camera.’ All good.
    Then I wanted to add another layer of text somewhere else in the shot, so I selected 3 track points somewhere else in the shot. Again I get the red bullseye and again I can ‘add text.’
    Now I want to add a 3rd layer of text, in a yet a different part of the shot. but my track points have disappeared. I checkbox ‘render trackpoints’ in the 3D camera tracker effect. Now I can see the track points, but I can’t select them or find the red bullseye.
    Any ideas? I can always get a red bullseye when I FIRST apply the tracker, but after that I sometimes can’t get another one for additional objects.
    AE CC 2014, Mac Pro, Mavericks 10.9.2
    David Markey replied 11 years, 10 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    October 24, 2014 at 2:28 am
    When applying the first solved point, choose ‘Add Camera, Shadow Catcher, Text/Null/Solid’. See if this helps.
    Also, if the Bullseye from one of the previous two solved points can be enabled again, you can push this Bullseye to a new location in the scene. To do this, move your cursor to the center of the Bullseye. You should notice that a new visual indicator appears at the bottom right of your cursor. This is the offset visual indicator. When it appears, you can offset the Bullseye to a new location in your scene.
    The accuracy of this offset is of course dependent on the integrity/accuracy of the source point(s).
    HTH
    – Roland
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • David Markey
    October 24, 2014 at 3:16 pm
    Your solution will give me extra layers in the same location, but doesn’t help with placing layers in totally different parts of the shot.
    I think I found the solution though. It seems that toggling ‘Mask Visibility’ in the Composition can bring back trackpoints and bullseyes that have gone missing.
    DM
