Activity › Forums › Maxon Cinema 4D › AE camera –> Cinema
AE camera –> Cinema
Posted by Colin James on June 7, 2006 at 2:45 pmI’ve got cameras going from Cinema4d to After Effects, no problem…but is there anyway to get the camera to go from AE to Cinema? I did a quick search and couldn’t find anything..
thanks!
Colin James replied 20 years, 3 months ago 3 Members · 7 Replies -
Mylenium
June 7, 2006 at 3:59 pmIt may be possible to create a script in AE that can write out data as XML in a C4D compliant format. Would be very tough to do, though, since it seems C4D needs all this junk data in its XML files. Adding all this noise and writing the proper entities in such a unnecessarily complex file would make the script very slow. Perhaps you should suggest this as a feature request to Maxon. I can’t see why it should be impossible for them to make use of their AEC format in both directions or write a simplified XML-importer just for that purpose.
Mylenium
[Pour Myl
Mylenium
June 8, 2006 at 5:27 am[sidefx] “and I cant understand why one should bring the aecamera into c4d
