Activity › Forums › Adobe After Effects › AE Blurs: Pro’s and Con’s?
  • AE Blurs: Pro’s and Con’s?
    Posted by Jordan Montreuil on August 23, 2008 at 2:11 am
    Through my time I have noticed that AE has so many different kinds of blurs to use. What would be really helpful is if someone would make an FAQ of the different blurs and pros and cons and which is best in which situation.
    Can anyone help?
    Barend Onneweer replied 18 years, 1 month ago 4 Members · 3 Replies
  • Sebastian Ballek
    August 23, 2008 at 5:21 am
    Never thougt about this, I always use Gaussian Blur as a standart and Lens Blur to simulate deph of field, blured lights or flares.
    Im very interest too if that helps to recive an awnser from someone who knows about different blurs.
  • Gary Hazen
    August 23, 2008 at 2:14 pm
    I’m not an expert by any means, but I’ll throw this out there.
    Fast Blur. As the name implies it render fast, however it’s not as accurate as the other blurs.
    Box Blur. Renders take a bit longer than fast blur, but it’s more accurate than fast blur.
    Gaussian. The most accurate of the three. Longest render time of the three.
    Compound blurs and Lens blurs require an additional layer (map) that’s drives the blur. These blurs are more complicated to use, but can produce some interesting results.
    That’s way over simplified, but it can help out when deciding which blur to use. Fast blur works fine in many instances.
  • Barend Onneweer
    August 24, 2008 at 3:36 pm
