Activity › Forums › Adobe After Effects › AE ‘blurring’ when I move an object
  • AE ‘blurring’ when I move an object
    Posted by Sean Brannigan on December 2, 2015 at 1:39 am
    I’m having a problem with AE.
    When I import an image it is nice and sharp.
    The problem is when I move the image, I’m trying to make an 8-bit animation, I get a blurring or more accurately it appears as it is being anti-aliased.
    I have no idea why it is doing this and cannot figure out how to stop it.
    I’ve uploaded an image so you can see what I mean
    It might not look like much but on a more detailed object the effect is really apparent.
    I’m using AE CS6 version 11.
    Thank you
    Sean Brannigan replied 10 years, 8 months ago 2 Members · 4 Replies
  • Kalleheikki Kannisto
    December 2, 2015 at 12:29 pm
  • Sean Brannigan
    December 2, 2015 at 2:14 pm
    Brilliant.
    That’s it.
    I would never have even known what words to use to do a google search.
    It works like a charm so thank you so much, I extremely happy with the result.
  • Sean Brannigan
    December 11, 2015 at 2:43 pm
    That did work on the first item I used it on but now for all the rest it offshoots them when I enter the expression so it leaves them with a constant AA effect.
    Cannot figure out how to stop it or why it worked the first time
  • Sean Brannigan
    January 24, 2016 at 6:30 pm
    What I ended up doing was setting the layers causing problems to draft and then when I rendered out the video I chenged the settings from Best to Current and that worked perfectly everytime
